Postupgrade Tasks for Applications Configuration
If applicable, review the results of the Person and Organization merge. Make configuration changes as required. For further information, see the topic about the Siebel Party Model in the chapter in Siebel Database Upgrade Guide that describes Siebel database and UI upgrade planning.
Perform the tasks in:
The chapter in Siebel Database Upgrade Guide that describes the postupgrade tasks for Siebel Business Applications
Verify the function of interfaces in integrated applications.
Deploy workflows. To perform these tasks, see Siebel Business Process Framework: Workflow Guide.
If you have set up integrations for transferring data to or from third-party applications using Siebel EAI, verify the integrations are configured correctly. For information on using EAI, see Overview: Siebel Enterprise Application Integration.
If you have used EIM to set up batch processing jobs, verify EIM is configured correctly. For information on using EIM, see Siebel Enterprise Integration Manager Administration Guide.
