Postupgrade Tasks for Database and File System
  1. Perform the applicable tasks in Postupgrade Tasks for Siebel Database and File System
  2. Perform the following tasks. For information on these tasks, see the chapter in Siebel Database Upgrade Guide that describes postupgrade tasks for the Siebel database and file system:
    • Check for inactivated EIM table columns in the Siebel database
    • Validate dock objects and rule definitions in the Siebel database
  3. Reset upgrade-specific database and database server parameters back to their recommended settings for production. See Siebel Installation Guide and Implementing Siebel Business Applications on DB2 for z/OS for recommended parameter settings.
  4. If you exported data from interface tables before the upgrade, review the database and import the data as desired.
  5. Upgrade unencrypted data and data that was encrypted using the standard encryptor to AES encryption. For information on this task, see the chapter in Siebel Database Upgrade Guide that describes Siebel database and UI upgrade planning.
Note: The development environment is now upgraded. The remaining sections deal with configuration and validation tasks.
