Creating Root Products for Rate Plans
To create root products for rate plans, follow this procedure
Navigate to the Administration - Product screen, then the Products view.
Add a record, and complete the necessary fields in the record and the form. To access more fields, click the show more button in the form.
Some fields are described in the following table.
Field Comments Type
Select Service for the type of product.
Service Type
Select the service type, such as Electricity or Gas.
Product Class
Select the class that you created for the service.
Price Type
Select the price type, such as Recurring (recommended for root products).
UoM
Select the unit of measurement. Per Month is the only unit of measurement supported for the standing charge.
