Setting Up Classes for Rate Plans
To set up classes for rate plans, follow this procedure.
Navigate to the Administration - Application screen, then the Class Administration view.
In the Classes list, add a record.
Typical class names are Electric Service, Gas Service, and Standard Electric Service.
Click the Dynamic Attributes view tab.
In the Dynamic Attributes list, add a record, and complete the following steps:
In the LOV Type field, click the select button.
In the Pick List of Values Type dialog box, select an existing type or add a record for a new LOV type.
In the Dynamic Attributes list, drill down on the LOV type of the attribute.
In the List of Values - Type list, add a record for each value that an end user can select for that LOV type.
Repeat Step 4 for each attribute you want to include.
Typical examples include Meter Type, Payment Method, Region, and Usage Type.
