Setting the System Preference for Integration
Administrators must set system preference values. The system preference described in this topic controls aspects of Oracle Application Integration Architecture integration functionality. For more information about system preferences, see Siebel Applications Administration Guide.
To set the system preference for integration
  1. Navigate to the Administration - Application screen, then the System Preferences view.
  2. Query for the Oracle Application Integration Architecture integration system preferences, and set the appropriate value for each.
    The Oracle Application Integration Architecture integration system preference for Siebel Energy is described in the following table.
    System Preference Comments
    Enable AIA Utility
    Enables or disables the CC&B Customer and Product Sync PIP. The default value is FALSE. To enable the CC&B Customer and Product Sync PIP, change the value to TRUE.
  3. Set other system preferences, if necessary.
  4. Restart the Siebel Server.
