Creating Criteria Library Sets
Use the following procedure to create a criteria library set.
To create a new criteria library set
Navigate to the Loyalty Promotions Administration screen, then the Criteria Library view.
Click New to create a new record.
Complete the necessary fields described in the following table.
Field Description Name
Name the Criteria Library set.
Note: The name must be unique.Library Category
Select the Library Category type.
Description
Describe the Criteria Library set.
Program Name
Enter the Program Name in which the Criteria Library set can be used.
Apply To
Select the Apply To type.
Create one or more criteria to the Criteria Library set created in step 3.
Create the criteria as you would normally. For information more about creating criteria, refer to Creating Criteria for Loyalty Promotion Rules.
