Process of Setting Up Loyalty Programs
To set up a loyalty program, the loyalty administrator performs the following tasks:
Note: A new loyalty program can require different lists of values
from existing loyalty programs. For example, it can use different
membership card types. If this is the case, then before you start
this process, create the appropriate lists of values, as described
in Defining Lists of Values for Siebel Loyalty.
