Defining Compatibility Groups
Compatibility groups are used to group compatibility rules that you create, for your own purposes.
For example, you can create one group for product compatibility rules and one group for promotion compatibility rules. Alternatively, you can create one group for each product line. You can use any logical group that makes sense to your business.
Note: Whatever the grouping, when compatibility is evaluated, all
rules of type compatibility will be evaluated against
all products, regardless of how they are logically grouped into Compatibility
Groups. The same is true of rules of type eligibility.
To define an compatibility group
Navigate to the Administration - Product screen, then the Eligibility and Compatibility Matrices view.
In the Eligibility and Compatibility Matrices list, add a new record and complete the necessary fields, as described in the following table.
Field | Comments |
Name |
Enter a name for a group. |
Matrix Type |
To make this an compatibility rule group, select Compatibility Rules. |
