Verifying the Variable Map for Pre-Pick Compatibility
Verify that the needed variable map definition is present for the following two variable maps:
  • Product Eligibility Variable Map - Context
  • Cfg Eligibility Variable Map - Context
To verify the variable map
  1. Navigate to the Administration - Order Management screen, then the Variable Maps view.
  2. Query to find the variable map named Product Eligibility Variable Map - Context.
  3. Drill-down on this variable map.
  4. In the Variable Map Definitions list, query to find Pre Pick Compatibility.
  5. If this definition is not found:
    1. Lock the variable map.
    2. Add a new record to the Variable Map Definitions list and complete the necessary fields, as described in the following table.
      Field Value
      Variable Name
      In/Out
      In
      Type
      Boolean
      On Null
      Ignore
    3. Add a new record to the Variable Source list and complete the necessary fields, as described in the following table.
      Field Value
      Mode
      Any
      Path
      PARAM_OM_PREPICK_COMPATIBILITY_FLAG
      Source Type
      Server Parameter
    4. Add another new record to the Variable Map Definitions list and complete the necessary fields, as described in the following table.
      Field Value
      Variable Name
      Pre Pick Mode
      In/Out
      In
      Type
      Text
      On Null
      Ignore
    5. Add a new record to the Variable Source list and complete the necessary fields, as described in the following table.
      Field Value
      Mode
      Any
      Path
      $Current/Header/Pre Pick Mode
      Source Type
      Instance
    6. Release the variable map.
  6. Repeat Step 1 to Step 5 for the variable map Cfg Eligibility Variable Map - Context.
  7. Clear the Cache.
