Defining Compatibility Rules for Product Lines
Before you can define a product line compatibility rule, you must define the product lines, and if necessary the products and product classes, it applies to, as described in Siebel Product Administration Guide.
To define compatibility rules for a product lines
  1. Navigate to the Administration - Product screen.
  2. Click the Eligibility and Compatibility Rules view tab.
  3. In the Eligibility and Compatibility Rules link bar, click Product Line Compatibility.
  4. Add a record to the Subject Compatibility Rules list or the Object Compatibility Rules list, and complete the necessary fields.
    These fields are similar to the fields used for product compatibility, except that you must choose a product line instead of a product as the subject product of a subject compatibility rule and as the object product of an object compatibility rule.
