Defining Compatibility Rules for Promotions
Before you can define promotion compatibility rule, you must define the product promotions it applies to, as described in the topic on product promotions in Siebel Pricing Administration Guide.
To define promotion compatibility rules
  1. Navigate to the Administration - Product screen.
  2. In the link bar, select Product Promotions.
  3. In the Product Promotions list, select the promotion you are defining rules for.
  4. Click the Eligibility and Compatibility Rules view tab.
  5. In the link bar of the Eligibility and Compatibility Rules view, click Product Compatibility.
  6. Add records to the Subject Compatibility Rules list and Object Compatibility Rules list, and define the rules in the same way that you do when you are defining product compatibility rules.
