Solution Assumptions and Constraints
The following are the Integration solution assumptions and constraints:
The files provided by the Integration to allow the batch synchronization of data support Oracle Database only.
For customer address data the following applies:
Only the primary customer address is synchronized between Oracle FLEXCUBE Universal Banking and Siebel CRM.
Nonprimary addresses in Siebel CRM are not deleted or updated.
If the lengths defined for corresponding columns in Siebel CRM and Oracle FLEXCUBE Universal Banking differ, then the data in the longer column is truncated during the synchronization process if the target column is smaller than the source column.
Siebel CRM is the master application for the following data:
Customer
Service request
Activity
Offers
Leads
Customer relationships
Oracle FLEXCUBE Universal Banking is the master application for the following data:
Products and prices
Branch
Financial account
Limit
Mandate
Standing instructions
Contracts
Transactions
A limited set of Oracle FLEXCUBE Universal Banking bank branch information is stored in Siebel CRM as an internal division.
