Getting Execution Status by Migration Plan Name, Resource Name, and Operation
You can get execution status by migration plan name, resource name, and operation for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get execution status by migration plan name, resource name, and operation for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}/{resourceName}/{operation} -
HTTP Method: GET
Content-Type: application/json
Authorization: Basic
Request Body: None
The following are the details for the response to a successful request:
HTTP Code: 200
            Response Body:
{ "id":"88-1V5WPF", "planName":"Test REST Execution", "description":"Test REST Execution", "status":"Running", "startDate":"2018-07-17 04:33:54", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5WPI", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Running", "startTime":"2018-07-17 04:33:55", "endTime":"", "resourceType":"" } ] }
