Getting Status for a Running Migration Plan by Plan Name and Resource Name
You can get status for a running migration plan by plan name and resource name for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get status for a running migration plan by plan name and resource name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}/{resourceName} -
HTTP Method: GET
Content-Type: application/json
Authorization: Basic
Request Body: None
The following are the details for the response to a successful request:
HTTP Code: 200
    Response Body:
{ "id":"88-1V60OJ", "planName":"Repo Export", "description":"Repo Export", "status":"Running", "startDate":"2018-08-17 06:02:39", "endDate":"", "source":"Dev", "target":"", "packageName":"irr_export.zip", "resources":[ { "id":"88-1V61H2", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Running", "startTime":"2018-08-17 06:02:39", "endTime":"", "resourceType":"DB Util" } ] }
