Enabling Persistence for a Workflow Process
You can enable Workflow Process persistence for an interactive Workflow Process or for a 7.0 flow Workflow Process. The Siebel Server sets persistence for a long-running Workflow Process at runtime.
To define persistence for a Workflow Process
Locate the Workflow Process want to modify.
Set the Auto Persist property to YES.
