Process Monitoring with Workflow Process Persistence
Some releases that occur earlier than Siebel CRM version 8.0 use Workflow Process persistence to monitor a Workflow Process. To control Workflow Process persistence, Siebel CRM adjusted the frequency and level settings on individual Workflow Process steps. Starting with Siebel CRM version 8.0, Workflow Process monitoring is separate from Workflow Process persistence and it is not necessary to set persistence for a long-running Workflow Process. If Workflow Process persistence is enabled for a 7.0 flow Workflow Process, then Siebel CRM enables Workflow Process persistence for it during an upgrade or import.
