How Persistence Works with Different Workflow Process Modes
Siebel CRM uses Workflow Process persistence with the following types of Workflow Processes:
Interactive Workflow Process or 7.0 flow Workflow Process. You set the Auto Persist property of the Workflow Process in the Workflow Processes list.
Long-running Workflow Process. The Siebel Server sets persistence for a long-running Workflow Process at runtime.
Service Workflow Process. Siebel CRM cannot use Workflow Process persistence with a service Workflow Process.
