Troubleshooting Problems That Occur During Simulation
The following table shows how to troubleshoot some common simulation problems by describing a symptom and then providing the corresponding solution to resolve the problem.
| Symptom | Diagnostic Steps or Cause | Solution |
When attempting to start a simulation, the Process Simulator does not run. |
If a runtime event is defined on the connector that emanates from a start step, then the Process Simulator waits for the event and never reaches the next step. |
Do one of the following:
When attempting to rerun the Process Simulator, an error dialog displays one of the following messages:
Navigating in the Siebel client during or after running the Process Simulator can cause a failure during subsequent attempts at running the simulator. |
Do not navigate in the Siebel client while the Process Simulator runs or after it ends. For more information, see Guidelines for Using the Process Simulator. |
After completing the user interact step, the Process Simulator fails to proceed to the next step in the Workflow Process. |
A branch from a user interact step might be missing an associated runtime event. |
Make sure the branches from the user interact step reference the runtime events that are associated with actions that the user performs on the user interact step. |
After the Siebel client starts, control does not return to Siebel or a dialog box indicates that the client is still starting, even after a long wait. |
N/A |
Restart processes that are currently running. |
An error message that is similar to the following message appears while the Process Simulator runs:
Errors in the Workflow Process configuration can occur during the simulation. These errors can result from errors in how objects are defined or how the Workflow Process uses objects. |
Close the Process Simulator, correct the configuration errors, and then run the simulation again. |
