Troubleshooting Problems That Occur During Validation
The following table shows how to troubleshoot some common validation problems by describing a symptom and then providing the corresponding solution to resolve the problem.
| Symptom | Diagnostic Steps or Cause | Solution |
Connector is not attached correctly. |
N/A |
Make sure you connect the connectors for the Workflow Process correctly. |
Conditional branch is not defined for a Decision step. |
N/A |
Make sure you define at least one conditional branch that emanates from each decision step in the Workflow Process. |
Business service and business service method are not defined for a business service step. |
N/A |
Make sure each business service step in the Workflow Process is not missing a business service or a business service method. |
Business component is missing from a Siebel Operation step. |
N/A |
Make sure each Siebel operation references a business component. |
Name of the sub process is not defined for a sub process step. |
N/A |
Make sure each sub process step references a sub process. |
