Using a Runtime Event with a Mobile Client
Some variation exists in the way a runtime event performs in a Siebel Mobile Web Client when compared with other Siebel client types. If you configure Siebel CRM to use a runtime event with a mobile client, then it is recommended that you set the processing mode to Local Synchronous or Remote Asynchronous. If Siebel CRM uses Remote Asynchronous for a mobile client, then it starts the Workflow Process after it synchronizes with the Siebel Server. For more information, see Remote Synchronous Processing.
