Configuring Default Tasks for Workflow Monitor Agent
Server Manager contains a parameter called 'Show Advanced Objects' that controls the display of all the objects that are marked for the advanced user.
Workflow Monitor Agent has a parameter called 'Default Tasks' which has been hidden and is available only to advanced users.
Use the following procedure to reveal this hidden parameter.
To display the Default Tasks parameter
  1. Navigate to the Administration - Server Configuration screen, then the Servers view.
  2. In the upper Siebel Servers applet, select the server on which you want to modify the parameter.
  3. Under the Component subtab, query for the Server Manager component.
  4. Under the Component Parameter subtab, query for 'Show Advanced Objects'.
  5. Change the value to 'True'.
  6. Click Advanced to change the Default Task parameter to 1.
    Note: You must log out from the current user session and log back in to the application in order for the parameter to take effect.
  7. Rename the existing diccache.dat file in the path Installed Directory\ses\siebsrvr\bin.
