Starting Tasks for Workflow Monitor Agent for Customer Synchronization
Use the following procedure to start tasks for the component that is online and enabled.
To start tasks for Workflow Monitor Agent
  1. Navigate to the Administration - Server Management screen.
  2. Select Tasks.
  3. Query for the WorkMonSWI task and start it. You can also use Server Manager to start the task.
  4. Start srvrmgr: Srvrmgr /g gatewayserver /e enterpriseserver /s siebelserver /u userid /p password
  5. Start the task for the WorkMonSWI component.
After about five minutes, check for log details for the task for the new workflow monitor component Workflow Monitor Agent SWI by navigating to the Administration - Server Management screen, then the Tasks view.
If there are errors, then check to see whether all configurations have been properly performed.
