Changing Which Fields Are Copied to the Product Issue
When the Create Product Issue button is used to create a product issue record from a service request record, data from various fields are copied from the service request record to the new product issue record.
To change which fields are copied when a product issue is created
Use the Data Transfer Utilities to edit the LS Medical Create PI from SR data map object.
For information about the Data Transfer Utilities, see Siebel Finance Guide.
