Business Component Events for Siebel eScript
The following table describes a summary of business component events you can use with Siebel eScript.
| Event | Description | Format |
Called if the user adds a business component record to create an association. |
Called if a business component record becomes the current record. |
Called if the user copies a business component record, and if the user makes this record the active record. |
Called if the user deletes a business component record. |
Called if Siebel CRM calls the InvokeMethod method on a business component. |
Called if the user creates a business component record, and if the user makes this record the active record. You can use this event to set up default values for a field. |
Called if Siebel CRM detects that the user is about to add a business component record to create an association. |
Called if Siebel CRM detects that the user is about to copy a business component record. You can use this event to perform precopy validation. |
Called if Siebel CRM detects that the user is about to delete a business component record. You can use this event to prevent the deletion or to perform any actions before Siebel CRM deletes the record. |
Called if a user accesses a business component field. |
Called if Siebel CRM calls a specialized method on a business component. Siebel CRM calls it before it calls this specialized method. |
Called if Siebel CRM detects that the user is about to create a new business component record. You can use this event to perform preinsert validation. |
Siebel CRM calls the BusComp_PreQuery event before it runs a query. You can use this event to modify the search criteria or to restrict Siebel CRM from running certain queries. |
Siebel CRM calls this event after the user modifies a field value or after a call to the SetFieldValue method occurs. This event allows you to use custom validation before Siebel CRM applies predefined validation. |
Called before Siebel CRM writes a record to the Siebel database. |
Called after Siebel CRM completes a query but before it displays the query results. |
Called if Siebel CRM sends a value to a business component from the Siebel client or through a call to the SetFieldValue method. |
Called after Siebel CRM saves the record to the Siebel database. |
