ActivateField Method for a Business Component |
Activates a field. |
var myBusComp;
myBusComp.ActivateField(fieldName);
ActivateMultipleFields Method for a Business Component |
Activates multiple fields. |
var myBusComp;
myBusComp.ActivateMultipleFields(oPr opSet);
Associate Method for a Business Component |
Creates a new many-to-many relationship for
the parent object through an association business component. |
var myBusComp;
myBusComp.Associate(whereIndicator);
BusObject Method for a Business Component |
Returns the name of the business object that
the business component references. |
var myBusComp;
var busObject;
busObject = myBusComp.BusObject();
ClearToQuery Method for a Business Component |
Clears the current query but does not clear
sort specifications on a business component. |
var myBusComp;
myBusComp.ClearToQuery();
DeactivateFields Method for a Business Component |
Deactivates the fields that are currently
active from the SQL query statement of a business component. |
var myBusComp;
myBusComp.DeactivateFields();
DeleteRecord Method for a Business Component |
Removes the current record from a business
component. |
var myBusComp;
myBusComp.DeleteRecord();
ExecuteQuery Method for a Business Component |
Returns a set of business component records. |
var myBusComp;
myBusComp.ExecuteQuery(cursorMode);
ExecuteQuery2 Method for a Business Component |
Allows you to control the number of records Siebel CRM returns. |
var myBusComp;
myBusComp.ExecuteQuery2(cursorMode, ignoreMaxCursorSize);
FirstRecord Method for a Business Component |
Moves the record pointer to the first record
in a business component, making that record the current record. |
var myBusComp;
var bIsRecord;
bIsRecord = myBusComp.FirstRecord();
FirstSelected Method for a Business Component |
Makes the first record of the multiple selection
in a business component active. |
var myBusComp;
var bIsMultipleSelection;
= myBusComp.FirstSelected();
GetAssocBusComp Method for a Business Component |
Returns the name of the association business
component. |
var myBusComp;
var AssocBusComp;
AssocBusComp = myBusComp.GetAssocBusComp();
GetFieldValue Method for a Business Component |
Returns the value of a field from the current
record of a business component. |
var myBusComp;
var sValue;
sValue = myBusComp.GetFieldValue(FieldName);
GetFormattedFieldValue Method for a Business Component |
Returns a field value that is in the same
format that the Siebel client uses. |
var myBusComp;
var sValue;
sValue = myBusComp.GetFormattedFieldValue(FieldName);
GetMultipleFieldValues Method for a Business Component |
Returns a value for each field specified
in a property set. |
var myBusComp;
myBusComp.GetMultipleFieldValues (oFields, oValues );
GetMVGBusComp Method for a Business Component |
Returns the multivalue group business component
that is associated a business component field. |
var myBusComp;
var MvgBusComp;
MvgBusComp= myBusComp.GetMVGBusComp(FieldName);
GetNamedSearch Method for a Business Component |
Returns the name of a search specification. |
var myBusComp;
var sValue;
sValue = myBusComp.GetNamedSearch(SearchName);
GetPicklistBusComp Method for a Business Component |
Returns the name of the pick business component
that is associated with a field in the current business component. |
var myBusComp;
var pickBusComp;
pickBusComp = myBusComp.GetPicklistBusComp
(FieldName);
GetSearchExpr Method for a Business Component |
Returns the current search expression that
is defined for a business component. |
var myBusComp;
var sExpr;
sExpr = myBusComp.GetSearchExpr();
GetSearchSpec Method for a Business Component |
Returns the search specification that is
var myBusComp;
var sSpec;
sSpec = myBusComp.GetSearchSpec(FieldName);
GetSortSpec Method for a Business Component |
Returns the sort specification for a business
component. |
var sSortSpec = this.GetSortSpec();
GetUserProperty Method for a Business Component |
Returns the value of a user property. |
var myBusComp;
var sValue;
sValue = myBusComp.GetUserProperty
(propertyName);
GetViewMode Method for a Business Component |
Returns the visibility mode for a business
component. |
var myBusComp;
var iMode;
iMode = myBusComp.GetViewMode();
InvokeMethod Method for a Business Component |
Calls a method. |
var myBusComp;
var sReturn;
sReturn = myBusComp.InvokeMethod(methodName, methodArg1, methodArg2,..., methodArgn);
LastRecord Method for a Business Component |
Moves the record pointer to the last record
in a business component. |
var myBusComp;
var iReturn;
iReturn = myBusComp.LastRecord();
Name Method for a Business Component |
Returns the name of a business component. |
var myBusComp;
var sName;
sName = myBusComp.Name();
NewRecord Method for a Business Component |
Adds a new record to a business component. |
var myBusComp;
myBusComp.NewRecord(whereIndicator);
NextRecord Method for a Business Component |
Moves the record pointer to the next record
var myBusComp;
var bFound;
bFound = myBusComp.NextRecord();
NextSelected Method for a Business Component |
Makes the next record of the current multiple
selection the active record. |
var myBusComp;
var iReturn;
iReturn = myBusComp.NextSelected();
ParentBusComp Method for a Business Component |
Returns the name of a parent business component. |
var myBusComp;
var parentBusComp;
parentBusComp = myBusComp.ParentBusComp();
Pick Method for a Business Component |
Places the currently chosen record in a pick
business component into the appropriate fields of the parent business
component. |
var myBusComp;
myBusComp.Pick();
PreviousRecord Method for a Business Component |
Moves the record pointer to the previous
record in a business component, making that record the current record. |
var myBusComp;
var iReturn;
iReturn = myBusComp.PreviousRecord();
RefineQuery Method for a Business Component |
Refines a query. |
var myBusComp;
myBusComp.RefineQuery();
SetFieldValue Method for a Business Component |
Sets a new value in a field for the current
var myBusComp;
myBusComp.SetFieldValue(FieldName,
FieldValue);
SetFormattedFieldValue Method for a Business Component |
Sets a new value in a field in the current
record of a business component. It accepts the field value in the
current local format. |
var myBusComp;
myBusComp.SetFormattedFieldValue (FieldName, FieldValue);
SetMultipleFieldValues Method for a Business Component |
Sets new values in the fields of the current
var myBusComp;
myBusComp.SetMultipleFieldValues (oPropSet);
SetNamedSearch Method for a Business Component |
Sets a named search specification on a business
component. |
var myBusComp;
myBusComp.SetNamedSearch(searchName,
searchSpec);
SetSearchExpr Method for a Business Component |
Sets a search expression for a business component. |
var myBusComp;
myBusComp.SetSearchExpr(searchSpec);
SetSearchSpec Method for a Business Component |
Sets the search specification for a business
component. |
var myBusComp;
myBusComp.SetSearchSpec(FieldName, searchSpec);
SetSortSpec Method for a Business Component |
Sets the sort specification for a business
component. |
var myBusComp;
myBusComp.SetSortSpec(sortSpec);
SetUserProperty Method for a Business Component |
Sets the value of a user property in a business
component. |
var myBusComp;
myBusComp.SetUserProperty (propertyName, newValue);
SetViewMode Method for a Business Component |
Sets the visibility type for a business component. |
var myBusComp;
myBusComp.SetViewMode(viewMode);
UndoRecord Method for a Business Component |
Reverses any unsaved modifications made to
the record. |
var myBusComp;
myBusComp.UndoRecord();
WriteRecord Method for a Business Component |
Saves to the Siebel database any modifications
made to the current record. |
var myBusComp;
myBusComp.WriteRecord();
