System Test Cases
System test cases are typically used in the system integration test phase to make sure that a component or module is built to specification. Functional tests focus on validating support for a scenario whereas system tests make sure that the structure of the application is correct. The following table shows some examples of typical system tests.
| Object Type | Example |
Interface |
Verify that an interface data structure has the correct data elements and correct data types. |
Business Rule |
Verify that a business rule (for example, assignment rule) handles all inputs and outputs correctly. |
