Importing with the Migration Application Data Service With Transformation
You can import a Migration Application Data Service With Transformation resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to import a resource:
- URI: - http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service With Transformation/Import
- HTTP Method: POST
- Content-Type: application/json
- Authorization: Basic
- Request parameters: -
            filename: Use the Tracking Id value that is present in the response from Exporting with the Migration Application Data Service With Transformation.
- migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
- Request body: - { "body": { "filename": "Tracking Id value>" "migrationid": "Migration Id> } }
The following are the details for the response to a successful request:
- HTTP Code: 200
- Response parameters: - trackingid: Returns the tracking identification value.
- Response body: - { "trackingid": "tracking id value>" }
