Using REST API with the Migration Incremental Runtime Repository Data Service
The Migration Incremental Runtime Repository Data Service identifies the version of the repository data that was previously migrated. If you select the latest migration version, then this service takes the changes from the previous migration version and latest version and migrates the data to the target environment. If you do not make any selections, the service only considers the latest migration version and migrates the data to the target environment.
The following table includes the methods supported for the Migration Incremental Runtime Repository Data Service.
| Method | Definition |
| Export | Method used to export the incremental Runtime Repository changes for a migration. For more information, see Exporting with the Migration Incremental Runtime Repository Data Service. |
| Import | Method used to import the incremental Runtime Repository for a migration. For more information, see Importing with the Migration Incremental Runtime Repository Data Service. |
| GetWatermark | Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Incremental Runtime Repository Data Service. |
| DBCheck | Method used to check a database has a migration. For more information, see Checking a Database with the Migration Incremental Runtime Repository Data Service. |
| GetStatus | Method used to get the status of a migration. For more information, see Getting Status with the Migration Incremental Runtime Repository Data Service. |
