Supported Upgrade Paths for Siebel CRM
The repository for the current release of Siebel CRM is SIA. Two types of optional repositories are offered while running Siebel CRM installer:
  1. Master Repository. This is required for the following situations:
    1. You are upgrading from a pre-Siebel CRM 17.0 release.
    2. You are creating a new Siebel CRM database instance.
  2. Ancestor Repositories. These are required if you are upgrading from a pre-Siebel CRM 17.0 release.
Review the information in the following table to determine if you need either of these repositories, and to ensure that they are available. If these repository options were not selected during installation, re-run the installer and add as needed. For more information, see Siebel Installation Guide for the operating system you are using.
Note: If there is a large backlog of Siebel Remote transactions in .dx files that have not been synced, then this will negatively impact the installation of monthly updates since these files will need to be copied to the backlog folder for the previous version.
Current Version
Upgrade Version
Upgrade Approach
Upgrade Tasks
Siebel CRM version 7.5.3 through version 7.7.2 (SEA or SIA repository)
Siebel CRM 22.7 Update
The upgrade approach is:
  • New installation of Siebel CRM 22.x Update for upgrade.
  • Two-step repository upgrade.
Perform the following two-step repository upgrade:
  • Upgrade to Siebel CRM version 8.1.1 (SEA or SIA repository).
  • Upgrade to Siebel CRM 22.7 Update using the incremental repository merge process.
For more information, see Performing the Siebel Incremental Repository Merge.
The current Siebel CRM version is one of the following:
  • 7.8.2 (SEA or SIA repository)
  • 8.0 (SEA or SIA repository)
  • 8.1.1.0 through version 8.1.1.7 (SEA repository)
  • 8.2 (SIA repository)
  • 8.2.1 (SIA repository)
  • Single-step repository upgrade.
Perform the following upgrade tasks:
  • Run Siebel CRM 22.7 Update installer to install the 22.7 Update binaries.
  • Perform a Siebel Database upgrade directly to Siebel CRM 22.7.
    Note: There is no need for any intermediary steps, such as, installation of or upgrade to Siebel CRM 17.0.
The New Customer Repository, generated through a three-way repository merge, contains all of the update content from Siebel CRM 22.7 Update. For more information about repository merge, see Performing the Siebel Repository Merge.
  • 8.1.1.0 through version 8.1.1.14 (SIA repository)
  • 8.2.2.0 through version 8.2.2.14 (SIA repository)
  • 15.0 through version 15.4
  • 15.5 and later patchsets
  • 16.0 and later patchsets of version 16.0
  • Migration installation of Siebel CRM 22.x Update.
  • Incremental repository merge.
  • Use incremental repository merge to bring the repository to 22.7 Update.
Siebel CRM version 17.0 or later
Not applicable.
Neither an Incremental Repository Merge nor a Database Upgrade is required for Siebel CRM 17.0 or later (including 18.x, 19.x, 20.x, and 22.x).
For more information on installing monthly updates, see the roadmap for installing Siebel CRM 22.x Update for an existing installation of Siebel CRM 17.x or later in Siebel Installation Guide for the operating system you are using.
Note: After installing the Siebel CRM software for the current release, you must reset any passwords stored in the Siebel Gateway that were previously encrypted using RC4 encryption. In the current release, such passwords are encrypted using Advanced Encryption Standard (AES) instead of RC4. For more information about re-encrypting passwords, see Siebel Security Guide.
