Performing the Siebel Incremental Repository Merge
This chapter provides guidelines for performing an incremental upgrade of the Siebel database. It includes the following topics:
Note: Use this chapter if you are upgrading from Siebel CRM version 8.1.1.x (SIA repository) through 16.x. For more information about incremental repository merge as it applies to different installation options, see Supported Upgrade Paths for Siebel CRM.
