Using REST API with the Migration Data Service with Transformation Service
The Migration Data Service with Transformation service migrates the data from the source environment to the target environment based on the tables listed in the datamig.inp file on the source environment.
While exporting the data, this service uses the rule defined in the datamig.rul file and performs the transformation. The transformed data will be migrated to the target environment.
The following table includes the methods supported for the Migration Data Service with Transformation Service.
| Method | Definition |
| Export | Method used to export the application data for a migration. For more information, see Exporting with the Migration Application Data Service With Transformation. |
| Import | Method used to import the application data for a migration. For more information, see Importing with the Migration Application Data Service With Transformation. |
| GetStatus | Method used to get the status of a migration. For more information, see Getting Status with the Migration Application Data Service With Transformation. |
