Verifying If a Schema Changed with the Migration Schema Service
You can check if a schema for a Migration Schema resource has changed by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to check if a schema has changed for a resource:
- URI: - http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/IsSchemaChanged
- HTTP Method: POST
- Content-Type: application/json
- Authorization: Basic
- Request parameter: - watermark: Use the watermark parameter to enter the watermark value.
- Request body: - { "body": { "watermark": "<watermark value>" } }
The following are the details for the response to a successful request:
- HTTP Code: 200
- Response parameters: - isschemachanged: Returns the value Y or N. Y indicated that the schema has changed. N indicates that the schema has not changed.
- Response body: - { "isschemachanged": "Y" }
