Importing with the Migration Schema Service
You can import a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to import a resource:
- URI: - http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/Import
- HTTP Method: POST
- Content-Type: application/json
- Authorization: Basic
- Request parameters: -
            filename: Use the Tracking Id value that is present in the response from Exporting with the Migration Schema Service.
- username: Use the user name parameter to enter your database user name.
            password: Use the password parameter to enter your database password, which must be in Base64 encoded format.
- migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
- Request body: - {"body":{ "filename": "<Tracking Id value>", "username": "<db username>", "password": "<base64 encoded database password>" "migrationid": "<Migration Id value> } }
The following are the details for the response to a successful request:
- HTTP Code: 200
- Response parameters: - trackingid: Returns the tracking identification value.
- Response body: - { "trackingid": "<tracking id value>" }
