About Team Member Work Distribution Filters
A Team Member filter, also known as a Team Member work distribution filter, extends the reporting capabilities of Team Member interface users. A work distribution filter is created to enable team members to update progress for selected labor resources, roles, and codes.
Multiple team members can be assigned the same filter if all are responsible for updating the same activities. For example, a team that works in shifts may have multiple supervisors. If each supervisor is responsible for updating the same group of activities, then they can all be assigned the same team member work distribution filter.
Use these filters when:
- Resource assignments or owners are not responsible for updating their own activities.
- Roles are assigned to an activity instead of a resource or owner.
- You want to update activities based on EPS or global activity codes.
Related Topics
Creating a Team Member Work Distribution Filter
Assigning a Team Member Work Distribution Filter
Last Published Wednesday, April 1, 2026
