Creating a Team Member Work Distribution Filter
Create Team Member work distribution filters to enable Team Member interface users to update progress for selected labor resources, roles, and global and EPS activity codes.
To create a Team Member work distribution filter:
  1. On the  Navigation Menu, expand  Administration and click User Administration.
  2. On the User Administration page, click Users.
  3. On the Users page:
    1. Select a user.
    2. In the Team Member Filter field, double-click and click  Select.
      Note If the Team Member Filter option is not displayed, click "" Customize View and select Team Member Filter.
  4. In the Team Member Filters dialog box:
    1. Click  Context and click Add.
      Note This filter is automatically applied to the user you selected. If you do not want to apply this filter to the selected user, then clear the Selected option.
    2. In the Name field, enter a name that describes the filter you are creating.
    3. In the Filter Details area:
      1. Configure the filter criteria.
      2. Click  Context and click Add to configure additional filter criteria.
    4. Click Save.
  5. On the Users page, click Save.
Related Topics
About Team Member Work Distribution Filters
Assigning a Team Member Work Distribution Filter
Last Published Wednesday, April 1, 2026
