Para mantener el entorno en espera actualizado con el entorno principal, utilice estos scripts para clonar el entorno principal de Oracle Fusion Cloud Enterprise Performance Management en el entorno en espera justo después de que haya terminado el mantenimiento diario en el entorno principal.
Estos scripts personalizados identifican si el mantenimiento diario programado para el día se ha realizado y, a continuación, clonan el entorno.
Script de Windows
Creedailyclone.ps1 copiando el siguiente script de PowerShell.
# Clone Environment script
# Update the following parameters
$users_and_predefined_roles="false"
$daily_maintenance_start_time="true"
$data_management="true"
$app_audit="true"
$job_console="true"
$stored_snapshots_and_files="false"
$source_username=$args[0]
$source_password=$args[1]
$source_url=$args[2]
$target_username=$args[3]
$target_password=$args[4]
$target_url=$args[5]
if ($($args.count) -ne 6) {
echo "Usage: ./dailyclone.ps1 <SOURCE USERNAME> <SOURCE PASSWORD> <SOURCE URL> <TARGET USERNAME> <TARGET PASSWORD> <TARGET URL>"
exit 1
$amw_time=""
function getDailyMaintenanceStartTime {
$amwstring=$(epmautomate.bat getDailyMaintenanceStartTime)
$elements=$amwstring.split(' ')
$amwtime=$elements[0]
return $amwtime
function goToSleep ($amw_time){
$current_mdy=Get-Date -AsUTC -UFormat "%m/%d/%Y"
$current_date_time=Get-Date -AsUTC -UFormat "%m/%d/%Y %H:%M:%S"
$current_epoch=Get-Date -Date $current_date_time -UFormat "%s"
$target_date_time=[DateTime]"${current_mdy} ${amw_time}"
$target_epoch=Get-Date -Date $target_date_time -UFormat "%s"
$sleep_seconds=$target_epoch - $current_epoch
# Today's AMW start time has already passed, so add 24 hours to sleep_seconds
if ($sleep_seconds -lt 0) {
$sleep_seconds=$sleep_seconds + 86400
$sleep_ts=New-TimeSpan -Seconds ${sleep_seconds}
$sleep_hms="${sleep_ts}" -replace '^\d+?\.'
echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}."
Start-Sleep -Seconds $sleep_seconds
function deleteArtifactSnapshotIfExists {
if (artifactSnapshotExists) {
$command_del=$(epmautomate.bat deletefile "Artifact Snapshot")
function artifactSnapshotExists {
$filelist=$(epmautomate.bat listfiles)
if ("$filelist".contains("Artifact Snapshot")) {
return $true
else
return $false
function cloneEnvironment {
echo "Checking to see if daily maintenance processing has completed ..."
while ($true) {
echo "Daily maintenance processing has completed ..."
break
} else {
echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..."
Start-Sleep -Seconds 30
echo "Encrypting target password ..."
epmautomate.bat encrypt "${target_password}" "oracleKey" "target_password.epw"
echo "Cloning environment ..."
epmautomate.bat cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}"
echo "Beginning clone environment script."
echo "Logging into server ..."
epmautomate.bat login ${source_username} ${source_password} ${source_url}
$amwtime=getDailyMaintenanceStartTime
goToSleep ($amwtime)
cloneEnvironment
echo "Logging out of server ..."
epmautomate.bat logout
echo "Clone environment script processing has completed."
Script de Linux/UNIX
Creedailyclone.sh copiando el siguiente script.
#!/bin/bash # Update the following parameters # ------------------------------- epmautomatescript="LOCATION_EPM_AUTOMATE_EXECUTABLE" javahome="LOCATION_JAVA_HOME" users_and_predefined_roles="false" data_management="true" app_audit="true" job_console="true" stored_snapshots_and_files="false" daily_maintenance_start_time="true" # ------------------------------- source_username="$1" source_password="$2" source_url="$3" target_username="$4" target_password="$5" target_url="$6" export JAVA_HOME=${javahome} if [ "$#" -ne 6 ]; then echo "Usage: ./dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL" exit 1 fi amw_time="" getDailyMaintenanceStartTime() { amw_time=$(${epmautomatescript} getDailyMaintenanceStartTime | cut -d' ' -f1) } goToSleep() { current_mdy=$(date -u +%m/%d/%Y) current_date_time=$(date -u) current_epoch=$(date +%s) target_epoch=$(date -d "${current_mdy} ${amw_time}" +%s) sleep_seconds=$(($target_epoch - $current_epoch)) # Today's AMW start time has already passed, so add 24 hours to sleep_seconds if [[ ${sleep_seconds} -lt 0 ]] then sleep_seconds=$((sleep_seconds + 86400)) fi sleep_hms=$(date -d@${sleep_seconds} -u +%H:%M:%S) echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}." sleep $sleep_seconds } deleteArtifactSnapshotIfExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then command_del=$(${epmautomatescript} deletefile "Artifact Snapshot") fi } artifactSnapshotExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then found=0 else found=1 fi echo ${found} } cloneEnvironment() { local found=1 while true do found=$(artifactSnapshotExists) if [[ ${found} -eq 0 ]] then echo "Daily maintenance processing has completed ..." break else echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..." sleep 30 fi done echo "Encrypting target password ..." ${epmautomatescript} encrypt "${target_password}" "oracleKey" "target_password.epw" echo "Cloning environment ..." ${epmautomatescript} cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}" } echo "Beginning clone environment script." echo "Logging into server ..." ${epmautomatescript} login ${source_username} ${source_password} ${source_url} getDailyMaintenanceStartTime goToSleep deleteArtifactSnapshotIfExists cloneEnvironment echo "Logging out of server ..." ${epmautomatescript} logout echo "Clone environment script processing has completed."
Script de Groovy
Cree el script Groovydailyclone copiando el siguiente código.
// Clone Environment script // Update the following parameters String source_username="USERNAME" String source_password="PASSWORD!" String source_url="URL OF THE SOURCE ENVIRONMENT" String target_username="USERNAME" String target_password="PASSWORD" String target_url="URL OF THE TARGET ENVIRONMENT" String snapshot_name="Artifact Snapshot" // ------------------------------- // Do not update the following parameters String users_and_predefined_roles="false" String data_management="true" String app_audit="true" String job_console="true" String stored_snapshots_and_files="false" String daily_maintenance_start_time="true" // ------------------------------- def LogMessage(String message) { def date = new Date() def sdf = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") println('[' + sdf.format(date) + '] ' + message); } def LogOperationStatus(EpmAutomateStatus opstatus) { def returncode = opstatus.getStatus() if (returncode != 0){ LogMessage(opstatus.getOutput()) } LogMessage('return code: ' + returncode) } def getDailyMaintenanceStartTime(EpmAutomate automate) { LogMessage("Operation: getDailyMaintenanceStartTime") EpmAutomateStatus amwtimestatus = automate.execute('getDailyMaintenanceStartTime') LogOperationStatus(amwtimestatus) def amwstring=(amwtimestatus.getOutput()) def elements=amwstring.split(' ') def amwtime=elements[0] return amwtime } def goToSleep(String amw_time){ def date = new Date() def current_mdy = new SimpleDateFormat("MM/dd/yyyy") def current_date_time = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") float current_epoch = date.getTime() / 1000 def pattern = "MM/dd/yyyy HH:mm:ss" def input = current_mdy.format(date) + " " + amw_time + ":00" def target_date_time = Date.parse(pattern, input) float target_epoch = target_date_time.getTime() / 1000 int sleep_seconds = Math.round(target_epoch - current_epoch) //Today's AMW start time has already passed, so add 24 hours to sleep_seconds if (sleep_seconds < 0) { sleep_seconds = sleep_seconds + 86400 } def sleep_milliseconds = sleep_seconds * 1000 LogMessage("Current time is " + current_date_time.format(date) + ". Sleeping until daily maintenance start time of " + amw_time + ":00.") sleep(sleep_milliseconds) } boolean artifactSnapshotExists(EpmAutomate automate,String snapshot_name) { LogMessage("Operation: listfiles") EpmAutomateStatus listfilesstatus = automate.execute('listfiles') String filelist=(listfilesstatus.getItemsList()) LogOperationStatus(listfilesstatus) if (filelist.contains(snapshot_name)) { return true } else { return false } } def deleteArtifactSnapshotIfExists(EpmAutomate automate,String snapshot_name){ if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Operation: deletefile " + snapshot_name) EpmAutomateStatus deletefilestatus = automate.execute('deletefile',snapshot_name) LogOperationStatus(deletefilestatus) } } def waitForDailyMaintenanceToComplete(EpmAutomate automate,String snapshot_name) { LogMessage("Checking to see if daily maintenance processing has completed ...") while (true) { if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Daily maintenance processing has completed ...") break } else { LogMessage("Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ...") sleep(30000) } } } LogMessage("Clone environment script processing beginning ...") EpmAutomate automate = getEpmAutomate() LogMessage("Operation: login " + source_username + " " + source_password + " " + source_url) EpmAutomateStatus status = automate.execute('login',source_username,source_password,source_url) LogOperationStatus(status) String amwtime = getDailyMaintenanceStartTime(automate) goToSleep (amwtime) deleteArtifactSnapshotIfExists(automate,snapshot_name) waitForDailyMaintenanceToComplete(automate,snapshot_name) LogMessage("Operation: encrypt " + target_password + " oracleKey target_password.epw") status = automate.execute('encrypt',target_password,'oracleKey','target_password.epw') LogOperationStatus(status) LogMessage("Operation: cloneEnvironment " + target_username + " target_password.epw " + target_url + " SnapshotName=" + snapshot_name + " UsersAndPreDefinedRoles=" + users_and_predefined_roles + " DataManagement=" + data_management + " appAudit=" + app_audit + " jobConsole=" + job_console + " storedSnapshotsAndFiles=" + stored_snapshots_and_files + " dailyMaintenanceStartTime=" + daily_maintenance_start_time) EpmAutomateStatus cloneenvironmentstatus = automate.execute('cloneEnvironment',target_username,"target_password.epw",target_url,"SnapshotName=" + snapshot_name,"UsersAndPreDefinedRoles=" + users_and_predefined_roles,"DataManagement=" + data_management,"appAudit=" + app_audit,"jobConsole=" + job_console,"storedSnapshotsAndFiles=" + stored_snapshots_and_files,"dailyMaintenanceStartTime=" + daily_maintenance_start_time) LogOperationStatus(cloneenvironmentstatus) LogMessage("Operation: logout ") status = automate.execute('logout') LogOperationStatus(status) LogMessage ("Clone environment script processing has completed.")
Ejecución del script
dailyclone.ps1, dailyclone.sh o el script Groovy dailyclone copiando un script de una de las secciones anteriores.Actualización para dailyclone.sh:
epmautomatescript con la ubicación del ejecutable de EPM Automate. Ejemplo: epmautomatescript="/home/utils/EPMAutomate/bin/epmautomate.sh"javahome con el directorio donde se instalar el JDK que utiliza EPM Automate. Por ejemplo: "/home/user1/jdk_17.0.12"dailyclone.ps1 y dailyclone.sh:
users_and_predefined_roles: establezca este valor en true para clonar usuarios y sus asignaciones de rol de aplicación (los grupos de EPM siempre se clonan).data_management: establezca este valor en false para no clonar registros de Data Integration. Tenga en cuenta que los registros de Data Integration solo se pueden clonar si tanto el entorno de origen como el de destino están en la misma actualización mensual o el entorno de destino está en una actualización más actual que el entorno de origen. Por ejemplo, puede clonar registros del entorno 22.01 de Data Management a otro entorno 22.01 o solo a un entorno de 22.02.
Se ignora para entornos de Narrative Reporting y Oracle Enterprise Data Management Cloud.
app_audit: establezca este valor en false si no desea clonar los datos de auditoría de aplicación para las aplicaciones de Planning, FreeForm y Enterprise Profitability and Cost Management.
La información de auditoría de Financial Consolidation and Close y Tax Reporting se clona siempre.
job_console: establezca este valor en false si no desea clonar los datos de la consola de trabajos.stored_snapshots_and_files: establezca este valor en true si desea clonar el contenido de las carpetas de nivel superior de la bandeja de entrada y el buzón de salida (las subcarpetas no se clonan nunca) del entorno de origen.daily_maintenance_start_time: establezca este valor en false si no desea restablecer la hora de inicio del mantenimiento del entorno clonado en la del entorno de origen.dailyclone:
source_username es el nombre de usuario de un administrador del servicio. Se necesita el rol Administrador de dominio de identidad para clonar usuarios y roles de aplicación.source_password es la contraseña del usuario identificado por SOURCE_USERNAME.source_url es la URL del entorno que desea clonar.target_username es el nombre de usuario de un administrador del servicio. Se necesita el rol Administrador de dominio de identidad para clonar usuarios y roles de aplicación.target_password es la contraseña del usuario identificado por TARGET_USERNAME.target_URL es la URL del entorno de destino.dailyclone.ps1, dailyclone.sh o el script Groovy dailyclone:
Windows
dailyclone.ps1../dailyclone.ps1 SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Consulte la tabla siguiente para ver una descripción de estos valores.Table 3-7 Descripción de los parámetros
| Parámetro | Descripción |
SOURCE_USERNAME |
Nombre de usuario de un administrador del servicio. Además, este usuario debe tener el rol Administrador de dominio de identidad para clonar usuarios y roles de aplicación. |
SOURCE_PASSWORD |
Contraseña del usuario identificado por SOURCE_USERNAME. |
SOURCE_URL |
URL del entorno que desea clonar. |
TARGET_USERNAME |
Nombre de usuario de un administrador del servicio en el entorno de destino. Además, este usuario debe tener el rol Administrador de dominio de identidad para clonar usuarios y roles de aplicación. |
TARGET_PASSWORD |
Contraseña del usuario identificado por TARGET_USERNAME. |
TARGET_URL |
URL del entorno de destino. |
dailyclone.sh../dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Consulte la tabla anterior para ver una descripción de estos valores.
