Eseguire le operazioni dei passi facoltativi descritti per abilitare la connettività remota per le funzioni classiche nelle analisi e nei dashboard.
Quando si imposta la connettività remota per le analisi e i dashboard, potrebbe essere necessario specificare le stringhe e le classi driver JDBC nonché i dettagli di connessione e di contesto JNDI.
Oracle:
Driver Class: oracle.jdbc.OracleDriver
jdbc string: jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=[\"host-name\"])(PORT=[\"port\"]))(CONNECT_DATA=(SERVICE_NAME=[\"service-name\"])))
Amazon Redshift:
Driver Class: com.oracle.jdbc.redshift.RedshiftDriver
JDBC String: jdbc:oracle:redshift://[\"host-name\"]:[\"port\"];DatabaseName=[\"service-name\"];EncryptionMethod=SSL;ValidateServerCertificate=false
Apache Hive
Driver Class: com.oracle.bi.jdbc.hive.HiveDriver
JDBC String: jdbc:oracle:hive://[\"host-name\"]:[\"port\"];EncryptionMethod=SSL;ValidateServerCertificate=false
DB2
Driver Class: com.oracle.bi.jdbc.db2.DB2Driver
JDBC String: jdbc:oracle:db2://[\"host-name\"]:[\"port\"];DatabaseName=[\"service-name\"]
Impala
Driver Class: com.oracle.bi.jdbc.impala.ImpalaDriver
JDBC String: jdbc:oracle:impala://[\"host-name\"]:[\"port\"];EncryptionMethod=SSL;ValidateServerCertificate=false
MySQL
Driver Class: com.mysql.cj.jdbc.Driver
JDBC String: jdbc:mysql://[\"host-name\"]:[\"port\"]"[/database][?properties]
SQL Server
Driver Class: com.oracle.bi.jdbc.sqlserver.SQLServerDriver
JDBC String: jdbc:oracle:sqlserver://[\"host-name\"]:[\"port\"];DatabaseName=[\"service-name\"]
Teradata
Driver Class: com.teradata.jdbc.TeraDriver
JDBC String: jdbc:teradata://[\"host-name\"]/DBS_PORT=[\"port\"] Oracle:
<Resource
name="jdbc/myoracle"
global="jdbc/myoracle"
auth="Container"
type="javax.sql.DataSource"
driverClassName="oracle.jdbc.OracleDriver"
url="jdbc:oracle:thin:@localhost:1521:orcl"
username="my_user"
password="my_password"
maxActive="15"
maxIdle="1"
maxWait="-1"
<Resource
name="jdbc/oracleolap"
global="jdbc/oracleolap"
auth="Container"
url="jdbc:oracle:thin:@localhost:1522:orcl112"
username="my_user"
maxActive="15"
maxIdle="1"
maxWait="-1"
<Resource
name="jdbc/oraclenorthwind"
global="jdbc/oraclenorthwind"
auth="Container"
url="jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=example.com)(PORT=1234))(CONNECT_DATA=(SERVICE_NAME=MATSDB.EXMAPLE.COM)))"
username="my_user"
maxActive="15"
maxIdle="1"
maxWait="-1"
DB2
<Resource
name="jdbc/db2northdb"
global="jdbc/db2northdb"
auth="Container"
driverClassName="com.ibm.db2.jcc.DB2Driver"
url="jdbc:db2://example.com:58263/NORTHDB"
username="my_user"
maxActive="15"
maxIdle="1"
maxWait="-1" />
SQLServer:
<Resource
name="jdbc/sqlservernorthwind"
global="jdbc/sqlservernorthwind"
auth="Container"
driverClassName="com.microsoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://example.com:61045;DatabaseName=Northwind"
username="my_user"
maxActive="15"
maxIdle="1"
maxWait="-1" />
Teradata:
<Resource
name="jdbc/teranorthwind"
global="jdbc/teranorthwind"
auth="Container"
driverClassName="com.teradata.jdbc.TeraDriver"
url="jdbc:teradata://99.999.99.999"
username="my_user"
maxActive="15"
maxIdle="1"
maxWait="-1" />
Mysql_community
<Resource
name="jdbc/CEmysql"
auth="Container"
type="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
factory="com.mysql.jdbc.jdbc2.optional.MysqlDataSourceFactory"
username="my_user"
serverName="example.com"
portNumber="3306"
databaseName="my_database" />The JNDI for DD Drivers.
SQLServer:
<Resource
name="jdbc/DDsqlserver"
auth="Container"
type="com.oracle.bi.jdbcx.sqlserver.SQLServerDataSource"
factory="com.oracle.bi.jdbcx.sqlserver.SQLServerDataSourceFactory"
user="my_user"
serverName="example.com\MSSQLSERVER16"
portNumber="61045"
DB2:
<Resource
name="jdbc/DDdb2"
auth="Container"
type="com.oracle.bi.jdbcx.db2.DB2DataSource"
factory="com.oracle.bi.jdbcx.db2.DB2DataSourceFactory"
user="my_user"
portNumber="58263"
Impala:
<Resource
name="jdbc/DDimpala"
auth="Container"
type="com.oracle.bi.jdbcx.impala.ImpalaDataSource"
factory="com.oracle.bi.jdbcx.impala.ImpalaDataSourceFactory"
user="my_user"
portNumber="21050"
Spark:
<Resource
name="jdbc/DDspark"
auth="Container"
type="com.oracle.bi.jdbcx.sparksql.SparkSQLDataSource"
factory="com.oracle.bi.jdbcx.sparksql.SparkSQLDataSourceFactory"
user="my_user"
portNumber="10000"
HIVE:
<Resource
name="jdbc/DDhive"
auth="Container"
type="com.oracle.bi.jdbcx.hive.HiveDataSource"
factory="com.oracle.bi.jdbcx.hive.HiveDataSourceFactory"
user="my_user"
portNumber="10000"
MySQL:
<Resource
name="jdbc/DDmysql"
auth="Container"
type="com.oracle.bi.jdbcx.mysql.MySQLDataSource"
factory="com.oracle.bi.jdbcx.mysql.MySQLDataSourceFactory"
user="my_user"
portNumber="3306"
MYSQL:
<Resource
name="jdbc/DDmysql"
auth="Container"
user="my_user"
portNumber="3306"
Aggiungere un driver JDBC all'installazione di Data Gateway in modo da poter modellare i dati in un database in locale.
In Oracle Analytics è possibile modellare i dati locali per molti tipi di database. Oracle Analytics supporta l'accesso diretto ad alcune origini dati in locale tramite il modello semantico. Quando si crea la connessione al database con Model Administration Tool, nel campo Nome origine dati della finestra di dialogo Connection pool (scheda Generale) è necessario utilizzare il formato DSN appropriato per il tipo di database al quale ci si connette.
Amazon Redshift:
DRIVER=Oracle 7.1 Amazon Redshift Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"]
SSL: DRIVER=Oracle 7.1 Amazon Redshift Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"];EM=6;CPV=TLSv1.2,TLSv1.1,TLSv1, SSLv3, SSLv2;VSC=0
Apache Drill:
DRIVER=MapR Drill ODBC Driver;Host=["host-name"];Port=["port"];CastAnyToVarchar=true;ExcludedSchemas=sys,INFORMATION_SCHEMA;AuthenticationType=Basic Authentication;ConnectionType=Direct
Aster:
DRIVER=Aster ODBC Driver;SERVER=["host-name"];PORT=["port"];DATABASE=["service-name"]
DB2:
DRIVER=Oracle 7.1 DB2 Wire Protocol;IpAddress=["host-name"];PORT=["port"];DB=["service-name"]
SSL: DRIVER=Oracle 7.1 DB2 Wire Protocol;IpAddress=["host-name"];PORT=["port"];DB=["service-name"];EM=1;VSC=0
Greenplum:
DRIVER=Oracle 7.1 Greenplum Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"]
Hive:
DRIVER=Oracle 8.0 Apache Hive Wire Protocol;HOST=["host-name"];PORT=["port"]
SSL: DRIVER=Oracle 8.0 Apache Hive Wire Protocol;HOST=["host-name"];PORT=["port"];EM=1;VSC=0
Impala:
DRIVER=Oracle 7.1 Impala Wire Protocol;HOST=["host-name"];PORT=["port"]
SSL: DRIVER=Oracle 7.1 Impala Wire Protocol;HOST=["host-name"];PORT=["port"];EM=1;VSC=0
Informix:
DRIVER=Oracle 7.1 Informix Wire Protocol;HOSTNAME=["host-name"];PORTNUMBER=["port"];DATABASE=["service-name"]
MongoDB:
DRIVER=Oracle 8.0 MongoDB;HOST=["host-name"];PORT=["port"];DB=["service-name"]
MySQL:
DRIVER=Oracle 7.1 MySQL Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"]
PostgresSql:
DRIVER=Oracle 7.1 PostgreSQL Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"]
Spark:
DRIVER=Oracle 8.0 Apache Spark SQL;HOST=["host-name"];PORT=["port"]
SSL: DRIVER=Oracle 8.0 Apache Spark SQL;HOST=["host-name"];PORT=["port"];EM=1;VSC=0
SQL Server:
DRIVER=Oracle 7.1 SQL Server Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"]
SSL: DRIVER=Oracle 7.1 SQL Server Wire Protocol;HOST=["host-name"];PORT=["port"];DB=["service-name"];EM=1;VSC=0;CryptoProtocolVersion=TLSv1.2,TLSv1.1,TLSv1,SSLv3,SSLv2
Sybase:
DRIVER=Oracle 7.1 Sybase Wire Protocol;NA=["host-name"], ["port"];DB=["service-name"]
Teradata:
DRIVER=Oracle 7.1 Teradata;DBCName=["host-name"];port_name=["port"]
