Affinché l'ambiente in standby resti sempre aggiornato e in linea con l'ambiente principale, utilizzare questi script per clonare l'ambiente Oracle Fusion Cloud Enterprise Performance Management principale nell'ambiente in standby non appena viene completata la manutenzione giornaliera sull'ambiente principale.
Questi script personalizzati identificano se è stata completata la manutenzione giornaliera pianificata e poi clonano l'ambiente.
Script per Windows
Crearedailyclone.ps1 by copiando lo script PowerShell riportato di seguito.
# Clone Environment script
# Update the following parameters
$users_and_predefined_roles="false"
$daily_maintenance_start_time="true"
$data_management="true"
$app_audit="true"
$job_console="true"
$stored_snapshots_and_files="false"
$source_username=$args[0]
$source_password=$args[1]
$source_url=$args[2]
$target_username=$args[3]
$target_password=$args[4]
$target_url=$args[5]
if ($($args.count) -ne 6) {
echo "Usage: ./dailyclone.ps1 <SOURCE USERNAME> <SOURCE PASSWORD> <SOURCE URL> <TARGET USERNAME> <TARGET PASSWORD> <TARGET URL>"
exit 1
$amw_time=""
function getDailyMaintenanceStartTime {
$amwstring=$(epmautomate.bat getDailyMaintenanceStartTime)
$elements=$amwstring.split(' ')
$amwtime=$elements[0]
return $amwtime
function goToSleep ($amw_time){
$current_mdy=Get-Date -AsUTC -UFormat "%m/%d/%Y"
$current_date_time=Get-Date -AsUTC -UFormat "%m/%d/%Y %H:%M:%S"
$current_epoch=Get-Date -Date $current_date_time -UFormat "%s"
$target_date_time=[DateTime]"${current_mdy} ${amw_time}"
$target_epoch=Get-Date -Date $target_date_time -UFormat "%s"
$sleep_seconds=$target_epoch - $current_epoch
# Today's AMW start time has already passed, so add 24 hours to sleep_seconds
if ($sleep_seconds -lt 0) {
$sleep_seconds=$sleep_seconds + 86400
$sleep_ts=New-TimeSpan -Seconds ${sleep_seconds}
$sleep_hms="${sleep_ts}" -replace '^\d+?\.'
echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}."
Start-Sleep -Seconds $sleep_seconds
function deleteArtifactSnapshotIfExists {
if (artifactSnapshotExists) {
$command_del=$(epmautomate.bat deletefile "Artifact Snapshot")
function artifactSnapshotExists {
$filelist=$(epmautomate.bat listfiles)
if ("$filelist".contains("Artifact Snapshot")) {
return $true
else
return $false
function cloneEnvironment {
echo "Checking to see if daily maintenance processing has completed ..."
while ($true) {
echo "Daily maintenance processing has completed ..."
break
} else {
echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..."
Start-Sleep -Seconds 30
echo "Encrypting target password ..."
epmautomate.bat encrypt "${target_password}" "oracleKey" "target_password.epw"
echo "Cloning environment ..."
epmautomate.bat cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}"
echo "Beginning clone environment script."
echo "Logging into server ..."
epmautomate.bat login ${source_username} ${source_password} ${source_url}
$amwtime=getDailyMaintenanceStartTime
goToSleep ($amwtime)
cloneEnvironment
echo "Logging out of server ..."
epmautomate.bat logout
echo "Clone environment script processing has completed."
Script Linux/UNIX
Crearedailyclone.sh copiando lo script riportato di seguito.
#!/bin/bash # Update the following parameters # ------------------------------- epmautomatescript="LOCATION_EPM_AUTOMATE_EXECUTABLE" javahome="LOCATION_JAVA_HOME" users_and_predefined_roles="false" data_management="true" app_audit="true" job_console="true" stored_snapshots_and_files="false" daily_maintenance_start_time="true" # ------------------------------- source_username="$1" source_password="$2" source_url="$3" target_username="$4" target_password="$5" target_url="$6" export JAVA_HOME=${javahome} if [ "$#" -ne 6 ]; then echo "Usage: ./dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL" exit 1 fi amw_time="" getDailyMaintenanceStartTime() { amw_time=$(${epmautomatescript} getDailyMaintenanceStartTime | cut -d' ' -f1) } goToSleep() { current_mdy=$(date -u +%m/%d/%Y) current_date_time=$(date -u) current_epoch=$(date +%s) target_epoch=$(date -d "${current_mdy} ${amw_time}" +%s) sleep_seconds=$(($target_epoch - $current_epoch)) # Today's AMW start time has already passed, so add 24 hours to sleep_seconds if [[ ${sleep_seconds} -lt 0 ]] then sleep_seconds=$((sleep_seconds + 86400)) fi sleep_hms=$(date -d@${sleep_seconds} -u +%H:%M:%S) echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}." sleep $sleep_seconds } deleteArtifactSnapshotIfExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then command_del=$(${epmautomatescript} deletefile "Artifact Snapshot") fi } artifactSnapshotExists() { found=1 filelist=$(${epmautomatescript} listfiles) if [[ ${filelist} == *"Artifact Snapshot"* ]] then found=0 else found=1 fi echo ${found} } cloneEnvironment() { local found=1 while true do found=$(artifactSnapshotExists) if [[ ${found} -eq 0 ]] then echo "Daily maintenance processing has completed ..." break else echo "Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ..." sleep 30 fi done echo "Encrypting target password ..." ${epmautomatescript} encrypt "${target_password}" "oracleKey" "target_password.epw" echo "Cloning environment ..." ${epmautomatescript} cloneEnvironment "${target_username}" "target_password.epw" "${target_url}" "SnapshotName=Artifact Snapshot" "UsersAndPreDefinedRoles=${users_and_predefined_roles}" "DataManagement=${data_management}" "appAudit=${app_audit}" "jobConsole=${job_console}" "storedSnapshotsAndFiles=${stored_snapshots_and_files}" "dailyMaintenanceStartTime=${daily_maintenance_start_time}" } echo "Beginning clone environment script." echo "Logging into server ..." ${epmautomatescript} login ${source_username} ${source_password} ${source_url} getDailyMaintenanceStartTime goToSleep deleteArtifactSnapshotIfExists cloneEnvironment echo "Logging out of server ..." ${epmautomatescript} logout echo "Clone environment script processing has completed."
Script Groovy
Creare lo script Groovydailyclone copiando il codice riportato di seguito.
// Clone Environment script // Update the following parameters String source_username="USERNAME" String source_password="PASSWORD!" String source_url="URL OF THE SOURCE ENVIRONMENT" String target_username="USERNAME" String target_password="PASSWORD" String target_url="URL OF THE TARGET ENVIRONMENT" String snapshot_name="Artifact Snapshot" // ------------------------------- // Do not update the following parameters String users_and_predefined_roles="false" String data_management="true" String app_audit="true" String job_console="true" String stored_snapshots_and_files="false" String daily_maintenance_start_time="true" // ------------------------------- def LogMessage(String message) { def date = new Date() def sdf = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") println('[' + sdf.format(date) + '] ' + message); } def LogOperationStatus(EpmAutomateStatus opstatus) { def returncode = opstatus.getStatus() if (returncode != 0){ LogMessage(opstatus.getOutput()) } LogMessage('return code: ' + returncode) } def getDailyMaintenanceStartTime(EpmAutomate automate) { LogMessage("Operation: getDailyMaintenanceStartTime") EpmAutomateStatus amwtimestatus = automate.execute('getDailyMaintenanceStartTime') LogOperationStatus(amwtimestatus) def amwstring=(amwtimestatus.getOutput()) def elements=amwstring.split(' ') def amwtime=elements[0] return amwtime } def goToSleep(String amw_time){ def date = new Date() def current_mdy = new SimpleDateFormat("MM/dd/yyyy") def current_date_time = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss") float current_epoch = date.getTime() / 1000 def pattern = "MM/dd/yyyy HH:mm:ss" def input = current_mdy.format(date) + " " + amw_time + ":00" def target_date_time = Date.parse(pattern, input) float target_epoch = target_date_time.getTime() / 1000 int sleep_seconds = Math.round(target_epoch - current_epoch) //Today's AMW start time has already passed, so add 24 hours to sleep_seconds if (sleep_seconds < 0) { sleep_seconds = sleep_seconds + 86400 } def sleep_milliseconds = sleep_seconds * 1000 LogMessage("Current time is " + current_date_time.format(date) + ". Sleeping until daily maintenance start time of " + amw_time + ":00.") sleep(sleep_milliseconds) } boolean artifactSnapshotExists(EpmAutomate automate,String snapshot_name) { LogMessage("Operation: listfiles") EpmAutomateStatus listfilesstatus = automate.execute('listfiles') String filelist=(listfilesstatus.getItemsList()) LogOperationStatus(listfilesstatus) if (filelist.contains(snapshot_name)) { return true } else { return false } } def deleteArtifactSnapshotIfExists(EpmAutomate automate,String snapshot_name){ if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Operation: deletefile " + snapshot_name) EpmAutomateStatus deletefilestatus = automate.execute('deletefile',snapshot_name) LogOperationStatus(deletefilestatus) } } def waitForDailyMaintenanceToComplete(EpmAutomate automate,String snapshot_name) { LogMessage("Checking to see if daily maintenance processing has completed ...") while (true) { if (artifactSnapshotExists(automate,snapshot_name)) { LogMessage("Daily maintenance processing has completed ...") break } else { LogMessage("Sleeping for 30 seconds before the next check to see if daily maintenance processing has completed ...") sleep(30000) } } } LogMessage("Clone environment script processing beginning ...") EpmAutomate automate = getEpmAutomate() LogMessage("Operation: login " + source_username + " " + source_password + " " + source_url) EpmAutomateStatus status = automate.execute('login',source_username,source_password,source_url) LogOperationStatus(status) String amwtime = getDailyMaintenanceStartTime(automate) goToSleep (amwtime) deleteArtifactSnapshotIfExists(automate,snapshot_name) waitForDailyMaintenanceToComplete(automate,snapshot_name) LogMessage("Operation: encrypt " + target_password + " oracleKey target_password.epw") status = automate.execute('encrypt',target_password,'oracleKey','target_password.epw') LogOperationStatus(status) LogMessage("Operation: cloneEnvironment " + target_username + " target_password.epw " + target_url + " SnapshotName=" + snapshot_name + " UsersAndPreDefinedRoles=" + users_and_predefined_roles + " DataManagement=" + data_management + " appAudit=" + app_audit + " jobConsole=" + job_console + " storedSnapshotsAndFiles=" + stored_snapshots_and_files + " dailyMaintenanceStartTime=" + daily_maintenance_start_time) EpmAutomateStatus cloneenvironmentstatus = automate.execute('cloneEnvironment',target_username,"target_password.epw",target_url,"SnapshotName=" + snapshot_name,"UsersAndPreDefinedRoles=" + users_and_predefined_roles,"DataManagement=" + data_management,"appAudit=" + app_audit,"jobConsole=" + job_console,"storedSnapshotsAndFiles=" + stored_snapshots_and_files,"dailyMaintenanceStartTime=" + daily_maintenance_start_time) LogOperationStatus(cloneenvironmentstatus) LogMessage("Operation: logout ") status = automate.execute('logout') LogOperationStatus(status) LogMessage ("Clone environment script processing has completed.")
Esecuzione dello script
dailyclone.ps1, dailyclone.sh o lo script Groovy dailyclone copiando uno script da una delle sezioni precedenti.Aggiornamento di dailyclone.sh:
epmautomatescript con la posizione dell'eseguibile di EPM Automate. Esempio: epmautomatescript="/home/utils/EPMAutomate/bin/epmautomate.sh"javahome con la directory in cui è installata la versione di JDK utilizzata da EPM Automate. Ad esempio: "/home/user1/jdk_17.0.12"dailyclone.ps1 e dailyclone.sh:
users_and_predefined_roles: impostare questo valore su true per clonare gli utenti e le relative assegnazioni di ruoli applicazione (i gruppi EPM vengono sempre clonati).data_management: impostare questo valore su false per non clonare i record di Data Integration. Notare che i record di Data Integration possono essere clonati solo se gli ambienti di origine e target sono entrambi inclusi nello stesso aggiornamento mensile o se l'ambiente target ha un solo livello di aggiornamento più recente rispetto all'ambiente di origine. I record di Data Management di un ambiente 22.01 ad esempio possono essere clonati solo in un altro ambiente 22.01 o in un ambiente 22.02.
Ignorato per gli ambienti Narrative Reporting e Oracle Enterprise Data Management Cloud.
app_audit: impostare questo valore su false se non si desidera clonare i dati di audit dell'applicazione per Planning, FreeForm e Enterprise Profitability and Cost Management.
Le informazioni di audit per Financial Consolidation and Close e Tax Reporting vengono sempre clonate.
job_console: impostare questo valore su false se non si desidera clonare i dati della console job.stored_snapshots_and_files: impostare questo valore su true se si desidera clonare il contenuto delle cartelle di livello superiore nelle cartelle inbox e outbox (le sottocartelle non vengono mai clonate) dell'ambiente di origine.daily_maintenance_start_time: impostare questo valore su false se non si desidera reimpostare l'ora di inizio della manutenzione dell'ambiente di target clonato in modo che corrisponda a quella dell'ambiente di origine.dailyclone:
source_username è il nome utente di un amministratore servizi. Il ruolo di amministratore del dominio di Identity è necessario per clonare gli utenti e i ruoli applicazione.source_password è la password dell'utente identificato da SOURCE_USERNAME.source_url è l'URL dell'ambiente da clonare.target_username è il nome utente di un amministratore servizi. Il ruolo di amministratore del dominio di Identity è necessario per clonare gli utenti e i ruoli applicazione.target_password è la password dell'utente identificato da TARGET_USERNAME.target_URL è l'URL dell'ambiente target.dailyclone.ps1, dailyclone.sh o lo script Groovy dailyclone:
Windows
dailyclone.ps1../dailyclone.ps1 SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Fare riferimento alla tabella che segue per una descrizione di questi valori.Table 3-7 Descrizione dei parametri
| Parametro | Descrizione |
SOURCE_USERNAME |
Nome utente di un amministratore servizi. È inoltre necessario che questo utente abbia il ruolo di amministratore del dominio di Identity per clonare utenti e ruoli applicazione. |
SOURCE_PASSWORD |
La password dell'utente identificato da SOURCE_USERNAME. |
SOURCE_URL |
L'URL dell'ambiente da clonare. |
TARGET_USERNAME |
Il nome utente di un amministratore servizi nell'ambiente target. È inoltre necessario che questo utente abbia il ruolo di amministratore del dominio di Identity per clonare utenti e ruoli applicazione. |
TARGET_PASSWORD |
La password dell'utente identificato da TARGET_USERNAME. |
TARGET_URL |
URL dell'ambiente target. |
dailyclone.sh../dailyclone.sh SOURCE_USERNAME SOURCE_PASSWORD SOURCE_URL TARGET_USERNAME TARGET_PASSWORD TARGET_URL. Fare riferimento alla tabella precedente per una descrizione di questi valori.Fare riferimento alla sezione Running Commands without Installing EPM Automate (in lingua inglese).
