使用这些脚本可从文件导入数据,刷新多维数据集,运行对多维数据集进行计算的业务规则,然后将数据推送到 ASO 多维数据集。
这些脚本执行以下操作:
data.csv
。loadingq1data
将数据从 data.csv
导入到应用程序中。Windows 示例脚本
通过复制以下脚本来创建importDataPlus.ps1
。将其保存到本地目录。
$inputproperties = ConvertFrom-StringData(Get-Content ./input.properties -raw) $username="$($inputproperties.username)" $passwordfile="$($inputproperties.passwordfile)" $serviceURL="$($inputproperties.serviceURL)" $importDataJobName="$($inputproperties.importDataJobName)" $businessRuleName="$($inputproperties.businessRuleName)" $planTypeMapName="$($inputproperties.planTypeMapName)" $param1Key="$($inputproperties.param1Key)" $param1Value="$($inputproperties.param1Value)" $param2Key="$($inputproperties.param2Key)" $param2Value="$($inputproperties.param2Value)" $clearData="$($inputproperties.clearData)" epmautomate login ${username} ${passwordfile} ${serviceURL} epmautomate uploadfile ${file1} epmautomate importdata ${importDataJobName} ${file1} epmautomate refreshcube epmautomate runbusinessrule ${businessRuleName} ${param1Key}=${param1Value} ${param2Key}=${param2Value} epmautomate runplantypemap ${planTypeMapName} clearData=${clearData} epmautomate logout
Linux/UNIX 示例脚本
。将其保存到本地目录。
#!/bin/bash . ./input.properties export JAVA_HOME=${javahome} ${epmautomatescript} login "${username}" "${passwordfile}" "${serviceURL}" ${epmautomatescript} uploadfile "${file1}" ${epmautomatescript} importdata "${importDataJobName}" "${file1}" ${epmautomatescript} refreshcube ${epmautomatescript} runbusinessrule "${businessRuleName}" "${param1Key}=${param1Value}" "${param2Key}=${param2Value}" ${epmautomatescript} runplantypemap "${planTypeMapName}" clearData=${clearData} ${epmautomatescript} logout
创建 input.properties 文件
Windows
username=exampleAdmin passwordfile=examplePassword.epw serviceURL=exampleURL File1=FILE_NAME.csv importDataJobName=FILE_NAME businessRuleName=RULE_NAME planTypeMapName=PLAN_TYPE_MAP_NAME param1Key=RUN-TIME PARAMETER_1 param1Value=RUN-TIME PARAMETER_1_VALUE param2Key=RUN-TIME PARAMETER_2 param2Value=RUN-TIME PARAMETER_2_VALUE clearData=trueLinux/UNIX
javahome=JAVA_HOME epmautomatescript=EPM_AUTOMATE_LOCATION username=exampleAdmin passwordfile=examplePassword.epw serviceURL=exampleURL File1=FILE_NAME.csv importDataJobName=FILE_NAME businessRuleName=RULE_NAME planTypeMapName=PLAN_TYPE_MAP_NAME param1Key=RUN-TIME PARAMETER_1 param1Value=RUN-TIME PARAMETER_1_VALUE param2Key=RUN-TIME PARAMETER_2 param2Value=RUN-TIME PARAMETER_2_VALUE clearData=true
表 3-17 input.properties 参数
参数 | 说明 |
javahome |
JAVA_HOME 位置。仅限 Linux/UNIX。 |
epmautomatescript |
EPM Automate 可执行文件 (epmautomate.sh ) 的绝对路径。仅限 Linux/UNIX。 |
username |
同时具有身份域管理员角色的服务管理员的用户名。 |
password |
服务管理员的密码或加密密码文件的名称和位置。 |
serviceURL |
要从其生成快照的环境的 URL。 |
File1 |
要将数据从其加载到应用程序中的导入文件。 |
iimportDataJobName |
用于导入数据的作业的名称。 |
businessRuleName |
要对导入的数据运行的业务规则 |
planTypeMapName |
用于将数据从 BSO 数据库复制到 ASO 数据库或从 BSO 数据库复制到另一个 BSO 数据库的规划类型映射。 |
param1Key |
要运行业务规则的运行时提示 1。 |
param1Value |
运行时提示 1 的值。 |
param2Key |
要运行业务规则的运行时提示 2。 |
param2Value |
运行时提示 2 的值。 |
clearData |
指示是否要删除接收数据库中的数据。指定 false 将保留数据。 |
运行脚本
importDataPlus.ps1
或 importDataPlus.sh
。input.properties
文件,并将其保存在 importDataPlus
脚本所在的目录中。此文件的内容因操作系统的不同而异。请参阅“创建 input.properties 文件”。
请确保您对此目录具有写权限。对于 Windows,您可能需要使用以管理员身份运行选项启动 PowerShell,以便能够运行脚本。
importDataPlus.ps1
。./importDataPlus.sh
