使用本節中的指令碼,以自動將「活動報表」從環境下載到本機電腦。
使用 syncAprReports.bat 以下載活動報表。您可以使用 Windows 排程器以排程批次檔案,以自動下載活動報表。如需關於活動報表的詳細資訊,請參閱使用活動報表與存取日誌監視使用狀況 in 管理員適用的入門手冊。
您可以藉由複製下列程序中提供的指令碼,然後更新連線參數,以手動建立 syncAprReports.bat。此指令碼會檢查環境,並僅下載比本機電腦之下載目錄中可用報表更新的報表。
註:
syncAprReports.bat,並將其儲存在方便的位置,例如,C:\automate_scripts。
@echo off
title APR
setlocal DisableDelayedExpansion
REM To hardcode the values in the script replace %1, %2, %3, and %4, with the actual values.
REM Example:
REM set apr_dir="C:\Oracle\apr"
REM set username="serviceAdmin"
REM set password="Ex@mple!"
REM set url="https://test-example.stg-pbcs.us1.oraclecloud.com"
set apr_dir=%1
set username=%2
set password=%3
set url=%4
setlocal EnableDelayedExpansion
set epmautomate_dir=%cd%
set lastfile=
set argC=0
for %%x in (%*) do Set /A argC+=1
if %argC% neq 0 (
if %argC% neq 3 (
if %argC% neq 4 (
goto :usage
goto :login
:usage
echo.
echo Invalid syntax. Please check the parameters.
echo Syntax:
echo 1) syncAprReports.bat APR_FolderPath_on_client username password_file url
echo or
echo 2) set the parameters in the file and use below syntax
echo syncAprReports.bat
goto :end
:login
for /f "delims=" %%i in ('epmautomate login %username% %password% %url%') do set result=%%i
if "Login successful" neq "%result%" (
echo Login Failed
goto :end
if not exist %apr_dir% (
echo.
echo apr folder does not exist
GOTO :end
cd /D %apr_dir%
for /f "delims=" %%D in ('dir /a:d /b /o:-n') do (
REM AFTER: for /f "delims=" %%D in ('dir /a-d /b /s /o:-n') do (
set "lastFile=%%~nD"
goto :next
:next
echo.
echo Most Recent APR on client is %lastFile%
set "output_cnt=0"
cd /D %epmautomate_dir%
for /F "delims=" %%f in ('epmautomate listfiles') do (
cd /D !apr_dir!
set "line=%%f"
for /f "tokens=* delims= " %%a in ("!line!") do set line=%%a
if "!line:~0,3!" equ "apr" (
if "!line:~4,8!" neq "Feedback" (
set isValidFile=false
if "!line:~-5!" equ ".html" set isValidFile=true
if "!line:~-5!" equ ".json" set isValidFile=true
if "!isValidFile!" equ "true" (
if "%lastFile%" lss "!line:~4,19!" (
if "!line:~4,19!" neq "!dirname!" (
set apr_dir=!apr_dir:"=!
set /a output_cnt+=1
set "output[!output_cnt!]=!apr_dir!\!line:~4,19!"
set "dirname=!line:~4,19!"
REM start downloading
mkdir "!dirname!"
cd /D !dirname!
echo downloading !line!
set "downloadDir=!apr_dir!\!dirname!"
for /f "delims=" %%i in ('epmautomate downloadfile "!line!"') do set result1=%%i
move "!line:~24!" "!downloadDir!" > nul
echo !result1!
REM end downloading
) else (
cd /D !dirname!
echo !result1!
REM end downloading
) else (
REM TO-DO
echo.
echo %output_cnt% APR's downloaded
for /L %%n in (1 1 !output_cnt!) DO echo !output[%%n]!
goto :end
:end
endlocal
syncAprReports.bat 以設定下表中參數的值。這些值用於存取環境以下載活動報表。
表格 3-3 要包含在 syncAprReports.bat 中的參數值
| 參數 | 預期值 |
apr_dir |
指定要下載活動報表的現有目錄。
範例: |
username= |
用於登入環境以下載活動報表的 Oracle Fusion Cloud Enterprise Performance Management 使用者名稱。
範例: |
password= |
儲存由 範例: |
url |
環境的 URL。
範例: |
syncAprReports.bat。如需瞭解詳細步驟,請參閱自動執行指令碼。
