通知使用者日常維護完成
Oracle Fusion Cloud Enterprise Performance Management 環境的日常維護時間通常比預計的 1 小時短得多。
在「活動報表」的「作業測量結果」區段中,系統會將環境的實際每日維護持續時間記錄成「每日維護持續時間 (分鐘)」測量結果的值。如果您不想先等 1 小時之後再使用環境,請使用此指令碼的自訂版本通知使用者日常維護已完成,讓他們可以恢復活動。
Windows 指令碼
透過複製下列 PowerShell 指令碼以建立 daily_maintenance_completed.ps1。如需有關如何根據自身需要更新指令碼的資訊,請參閱執行指令碼。
# Daily Maintenance Completed Notification script
# Update the following parameters
$emailaddresses=user1@oracle.com,user2@oracle.com
$username=$args[0]
$password=$args[1]
$url=$args[2]
if ($($args.count) -ne 3) {
    echo "Usage: ./daily_maintenance_completed.ps1 <USERNAME> <PASSWORD> <URL>"
    exit 1
$amw_time=""
function getDailyMaintenanceStartTime {
    $amwstring=$(epmautomate.bat getDailyMaintenanceStartTime)
    $elements=$amwstring.split(' ')
    $amwtime=$elements[0]
    return $amwtime
function goToSleep ($amw_time){
    $current_mdy=Get-Date -AsUTC -UFormat "%m/%d/%Y"
    $current_date_time=Get-Date -AsUTC -UFormat "%m/%d/%Y %H:%M:%S"
    $current_epoch=Get-Date -Date $current_date_time -UFormat "%s"
    $target_date_time=[DateTime]"${current_mdy} ${amw_time}"
    $target_epoch=Get-Date -Date $target_date_time -UFormat "%s"
    $sleep_seconds=$target_epoch - $current_epoch
    # Today's AMW start time has already passed, so add 24 hours to sleep_seconds
    if ($sleep_seconds -lt 0) {
        $sleep_seconds=$sleep_seconds + 86400
    $sleep_ts=New-TimeSpan -Seconds ${sleep_seconds}
    $sleep_hms="${sleep_ts}" -replace '^\d+?\.'
    echo "Current time is ${current_date_time}. Sleeping for ${sleep_hms}, until daily maintenance start time of ${amw_time}."
    Start-Sleep -Seconds $sleep_seconds
function attemptLogin {
    $serverdown=$False
    while ($true) {
        epmautomate.bat login ${username} ${password} ${url}
        if ($?) { # login succeeded
            if ($serverdown) { # server has been brought down
                echo "Daily maintenance processing has completed ..."
                break
            } else { # server has not yet been brought down
                echo "Daily maintenance processing has not yet started. Sleeping for 2 minutes before the next check ..."
                Start-Sleep -Seconds 120
        } else { # login failed
                echo "Waiting for daily maintenance processing to complete. Sleeping for 2 minutes before the next check ..."
                echo "Daily maintenance processing is now beginning. Sleeping for 2 minutes before the next check ..."
                $serverdown=$True
function sendNotification {
    $servername=$url.split("/")[2];
    $subject="Daily maintenance processing has completed"
    $formattedmessage="Daily maintenance processing has completed for server ${servername}"
    $emailaddresses=${emailaddresses}.replace(',',';')
    echo "Mailing report"
    epmautomate.bat sendmail "${emailaddresses}" "${subject}" Body="${formattedmessage}"
echo "Beginning daily maintenance completion notification script."
echo "Logging into server ..."
$amwtime=getDailyMaintenanceStartTime
goToSleep ($amwtime)
attemptLogin
sendNotification
echo "Logging out of server ..."
epmautomate.bat logout
echo "Script processing has completed."
Linux/UNIX 指令碼
透過複製下列指令碼以建立 daily_maintenance_completed.sh。如需有關如何根據自身需要更新指令碼的資訊,請參閱執行指令碼。
#!/bin/bash
epmautomatescript="LOCATION_EPM_AUTOMATE_EXECUTABLE"
javahome="LOCATION_JAVA_HOME"
emailaddresses=EMAIL_ADDRESS_1,EMAIL_ADDRESS_2,EMAIL_ADDRESS_N
username="$1"
password="$2"
url="$3"
export JAVA_HOME=${javahome}
if [ "$#" -ne 3 ]; then
    echo "Usage: ./daily_maintenance_completed.sh <USERNAME> <PASSWORD> <URL>"
    exit 1
fi
amw_time=""
getDailyMaintenanceStartTime() {
    amw_time=$(${epmautomatescript} getDailyMaintenanceStartTime | cut -d' ' -f1)
goToSleep() {
    current_mdy=$(date -u +%m/%d/%Y)
    current_date_time=$(date -u)
    current_epoch=$(date +%s)
    target_epoch=$(date -d "${current_mdy} ${amw_time}" +%s)
    sleep_seconds=$(($target_epoch - $current_epoch))
    if [[ ${sleep_seconds} -lt 0 ]]
    then
        sleep_seconds=$((sleep_seconds + 86400))
    fi
    sleep_hms=$(date -d@${sleep_seconds} -u +%H:%M:%S)
    sleep $sleep_seconds
attemptLogin() {
    local serverdown=1
    while true
    do
        ${epmautomatescript} login ${username} ${password} ${url}
        if [[ $? -eq 0 ]] # login succeeded
        then
            if [[ ${serverdown} -eq 0 ]] # server has been brought down
            then
                echo "Daily maintenance processing has completed"
                break
            else # server has not yet been brought down
                sleep 120
            fi
        else # login failed
            then
                sleep 120
                sleep 120
                serverdown=0
            fi
        fi
    done
sendNotification()
    local servername=$(echo "${url}" | cut -d '/' -f3- | rev | cut -d':' -f2- | rev)
    local subject="Daily maintenance processing has completed"
    local formattedmessage="Daily maintenance processing has completed for server ${servername}"
    local emailaddresses=$(echo ${emailaddresses} | sed "s/,/;/g")
    ${epmautomatescript} sendmail "${emailaddresses}" "${subject}" Body="${formattedmessage}"
goToSleep
attemptLogin
sendNotification
${epmautomatescript} logout
伺服器端 Groovy 指令碼
透過複製下列程式碼以建立 daily_maintenance_completed Groovy 指令碼。如需有關如何根據自身需要更新指令碼的資訊,請參閱執行指令碼。
// Daily Maintenance Completed Notification script
// Update the following parameters
String username="USERNAME"
String password="PASSWORD"
String url="URL OF THE ENVIRONMENT"
String emailaddresses="EMAIL_ADDRESS_1,EMAIL_ADDRESS_2,EMAIL_ADDRESS_N"
def LogMessage(String message) {
    def date = new Date()
    def sdf = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss")
    println('[' + sdf.format(date) + '] ' + message);
def LogOperationStatus(EpmAutomateStatus opstatus) {
    def returncode = opstatus.getStatus()
    if (returncode != 0){
        LogMessage(opstatus.getOutput())
    LogMessage('return code: ' + returncode)
def getDailyMaintenanceStartTime(EpmAutomate automate) {
    LogMessage("Operation: getDailyMaintenanceStartTime")
    EpmAutomateStatus amwtimestatus = automate.execute('getDailyMaintenanceStartTime')
    LogOperationStatus(amwtimestatus)
    def amwstring=(amwtimestatus.getOutput())
    def elements=amwstring.split(' ')
    def amwtime=elements[0]
    return amwtime
def goToSleep(String amw_time){
    def current_mdy = new SimpleDateFormat("MM/dd/yyyy")
    def current_date_time = new SimpleDateFormat("MM/dd/yyyy HH:mm:ss")
    float current_epoch = date.getTime() / 1000
    def pattern = "MM/dd/yyyy HH:mm:ss"
    def input = current_mdy.format(date) + " " + amw_time + ":00"
    def target_date_time = Date.parse(pattern, input)
    float target_epoch = target_date_time.getTime() / 1000
    int sleep_seconds = Math.round(target_epoch - current_epoch)
    //Today's AMW start time has already passed, so add 24 hours to sleep_seconds
    if (sleep_seconds < 0) {
        sleep_seconds = sleep_seconds + 86400
    def sleep_milliseconds = sleep_seconds * 1000
    LogMessage("Current time is " + current_date_time.format(date) + ". Sleeping until daily maintenance start time of " + amw_time + ":00.")
    sleep(sleep_milliseconds)
def attemptLogin(EpmAutomate automate, String username, String password, String url) {
    def serverdown=1
    while (true) {
        LogMessage("Operation: login " + username + " " + password + " " + url)
        EpmAutomateStatus status = automate.execute('login',username,password,url)
        def returncode = status.getStatus()
        if (returncode == 0) {
            if (serverdown == 0){
                LogMessage("Daily maintenance processing has completed ...")
                break
            } else {
                LogMessage("Daily maintenance processing has not yet started. Sleeping for 2 minutes before the next check ...")
                sleep(120000)
        } else {
                LogMessage("Waiting for daily maintenance processing to complete. Sleeping for 2 minutes before the next check ...")
                sleep(120000)
            } else {
                LogMessage("Daily maintenance processing is now beginning. Sleeping for 2 minutes before the next check ...")
                sleep(120000)
                serverdown=0
def sendNotification(EpmAutomate automate, String url, String emailaddresses) {
    def servername=url.tokenize("/")[-1];
    def subject="Daily maintenance processing has completed"
    def formattedmessage="Daily maintenance processing has completed for server " + servername
    def emailaddressesformatted = emailaddresses.replaceAll(',',';')
    LogMessage("Operation: sendmail " + emailaddressesformatted + " " + subject + " Body=" + formattedmessage)
    EpmAutomateStatus status = automate.execute('sendmail',emailaddressesformatted,subject,'Body=' + formattedmessage)
    LogOperationStatus(status)
LogMessage("Beginning daily maintenance completion notification script.")
EpmAutomate automate = getEpmAutomate()
String amwtime = getDailyMaintenanceStartTime(automate)
goToSleep (amwtime)
attemptLogin(automate,username,password,url)
sendNotification(automate,url,emailaddresses)
LogMessage("Operation: logout ")
status = automate.execute('logout')
LogMessage ("Script processing has completed.")
執行指令碼
Windows 和 Linux/UNIX
  1. 透過複製上一節的指令碼以建立 daily_maintenance_completed.ps1 或 daily_maintenance_completed.sh。
  2. 更新指令碼:
    • Windows:將 emailaddresses 的更新為日常維護完成時應通知的電子郵件地址清單 (逗號分隔)。
    • Linux/UNIX:更新下列變數:
      • epmautomatescript 以及 EPM Automate 可執行檔的位置。範例:epmautomatescript="/home/utils/EPMAutomate/bin/epmautomate.sh"
      • javahome 改成 EPM Automate 使用之 JDK 的安裝目錄。例如:"/home/user1/jdk_17.0.12"
      • emailaddresses 改成日常維護完成時應通知的電子郵件地址清單 (逗號分隔)。範例:jdoe@example.com,jane_doe@example.com
  3. 在「命令視窗」或「主控台」中,瀏覽至儲存 daily_maintenance_completed 指令碼的資料夾。
  4. 執行這個命令:
    • Windows:./daily_maintenance_completed.ps1 USERNAME PASSWORD URL
    • Linux/UNIX: ./daily_maintenance_completed.sh USERNAME PASSWORD URL,其中:
      • USERNAME 為服務管理員的使用者名稱
      • PASSWORD 為服務管理員的密碼
      • URL 是 Cloud EPM 環境的 URL
伺服器端 Groovy:
  1. 透過複製上一節中的指令碼以建立 daily_maintenance_completed.groovy Groovy 指令碼。
  2. 更新這些值。
    • username 改成服務管理員的使用者名稱。
    • password 改成服務管理員的密碼。
    • url 包含需要為其發出日常維護完成通知的 Cloud EPM 環境 URL。範例:範例:https://testExample-idDomain.pbcs.us1.oraclecloud.com
  3. 使用 Cloud EPM 商業程序中的 Groovy 畫面,或使用 runBusinessRule 自動執行指令碼。如需詳細資訊,請參閱下列資訊來源:
