Working with the Managed Product Specification
All Project entities in UIM are based on the Managed Project specification. You can extend this specification by defining entity-level characteristics. When you define entity-level characteristics for this specification and deploy the cartridge that contains it to UIM, the new characteristics apply to all Project entities.
Related Topics
Extending Predefined Specifications
Entity Extension Editor
