OCNRF Upgrade
This section includes information about upgrading an existing NRF deployment.
When you attempt to upgrade an existing OCNRF deployment, the running set of containers and pods are replaced with the new set of containers and pods. However, If there is no change in the pod configuration, the running set of containers and pods are not replaced.
ocnrf-custom-values-1.2.0.yaml
file with new values.
It is advisable to create a backup of the file before changing any configuration.To configure the parameters, see section OCNRF Configuration
$ helm upgrade <release> <helm chart> [--version <OCNRF version>] -f <ocnrf_customized_values.yaml>
For example:
$ helm upgrade
To check the status of the upgrade, execute:
helm status <helm-release>
For example:
helm status
ocnrf
Caution:
Upgrading OCNRF within same release supports only configuration changes.Table 4-1 Parameters and Definitions during OCNRF Upgrade
| Parameters | Definitions |
<helm chart>
It is the name of the chart that is of the
form
<repository/ocnrf>.
For example:
reg-1/ocnrf
or cne-repo/ocnrf
<release>
It can be found in the output of
helm
list command
- Check the history of helm
deployment:
helm history <helm_release> - Rollback to the required
revision:
helm rollback <release name> <revision number>
