SCP Uninstall
SCP deployment can be uninstalled as follows. The steps below need to be executed from a server that has access to Kubectl and helm commands.
Table 2-6 SCP Uninstall
| Step # | Procedure | Description |
1
Undeploy SCP |
Execute the following command to uninstall SCP: $ helm delete <deployment_name> --purge |
2
Remove SCP custom resources definitions |
Execute the following command to remove SCP custom resources definitions: $ kubectl get crds -o name | grep <deployment_name>.oracle.io | xargs kubectl delete Example:
3
Delete namespace |
Execute the following command to delete the namespace: kubectl delete namespace <deployment_name> Note: Deleting the namespace deletes all the other Kubernates objects in that namespace. |
