Configure SCP as HTTP Proxy
Customer NFs are required to set http_proxy/HTTP_PROXY to scp-worker's <FQDN or IPV4 address>:<PORT of SCP-Worker> for customer NFs to route messages towards SCP.
Also, all NFs are required to register with NRF so that SCP can create rules based on the notifications from NRF.
Execute these command from where SCP worker and FQDN can be accessed.
Table 2-5 Configure SCP as HTTP Proxy
Step # Procedure Description
1
Test successful deployment of SCP To test that SCP deployed successfully and is able to receive a message as a proxy and route it to the appropriate producer, use the below curl command:
$ curl -v -X GET --url 'http://<FQDN:PORT of SCP-Worker>/nnrf-nfm/v1/subscriptions/' --header 'Host:<FQDN:PORT of NRF>'
2
Fetch the current subscription list
The curl command fetches the current subscription list (as a client) from NRF by sending the request to NRF via SCP.
Example:
$ curl -v -X GET --url 'http://scp-worker.scpsvc:8000/nnrf-nfm/v1/subscriptions/' --header 'Host:ocnrf-ambassador.nrfsvc:80'
