Inventory File Template
Template example
The
host.ini file contains
the inventory used by the various OCCNE deployment containers that will
instantiate the OCCNE cluster.
The inventory is composed of multiple groups (indicated by bracketed
strings):
- local: OCCNE ansible use. Do not modify.
- occne: list of servers in the OCCNE cluster that will be installed by the os_install container.
- k8s-cluster: list of servers in the kubernetes cluster.
- kube-master: list of servers that will be provisioned as kubernetes master nodes by the k8s_install container.
- kube-node: list of servers that will be provisioned as kubernetes worker nodes by the k8s_install container.
- etcd: list of servers that will be provisioned as part of kubernetes etcd cluster by the k8s_install container.
- data_store: list of servers that will be host the VMs of the MySQL database cluster, os_install container will install kvm on them.
- occne:vars: list of occne environment variables. Values for variables are required. See below for description.
OCCNE Variables
Table B-14 OCCNE Variables
| Var Name | Description/Comment |
| occne_cluster_name | Set to the OCCNE Cluster Name generated in step 2.1 above. |
| subnet_ipv4 | Set to the subnet of the network used to assign IPs for OCCNE hosts |
| subnet_cidr | Appears this is not used so does not need to be included. If it does need to be included, set to the cidr notation for the subnet. For example /24 |
| netmask | Set appropriately for the network used to assign IPs for OCCNE hosts. |
| broadcast_address | Set appropriately for the network used to assign IPs for OCCNE hosts. |
| default_route | Set to the IP of the TOR switch. |
| name_server | 'none' |
| ntp_server | Set to the IP of the TOR switch. |
| occne_repo_host | Set to the hostname of the bootstrap host initially. This defaults to "bootstrap". It can remain as that value or the user can change it to their own specifications but they must adhere to hostname conventions. |
| occne_repo_host_address | Set to the internal (ansible_host) IPv4 address of the occne_repo_host. |
| pxe_install_lights_out_usr | Set to the user name configured for iLO admins on each host in the OCCNE Frame. |
| pxe_install_lights_out_passwd | Set to the password configured for iLO admins on each host in the OCCNE Frame. |
| ilo_vlan_id | Set to the VLAN ID of the ILO network For Ex: 2 |
| ilo_subnet_ipv4 | Set to the subnet of the ILO network used to assign IPs for Storage hosts |
| ilo_subnet_cidr | Set to the cidr notation for the subnet. For example 24 |
| ilo_netmask | Set appropriately for the network used to assign ILO IPs for Storage hosts. |
| ilo_broadcast_address | Set appropriately for the network used to assign ILO IPs for OCCNE hosts. |
| ilo_default_route | Set to the ILO VIP of the TOR switch. |
| mgmt_vlan_id | Set to the VLAN ID of the Management network For Ex: 4 |
| mgmt_subnet_ipv4 | Set to the subnet of the Management network used to assign IPs for Storage hosts |
| mgmt_subnet_cidr | Set to the cidr notation for the Management subnet. For example 29 |
| mgmt_netmask | Set appropriately for the network used to assign Management IPs for Storage hosts. |
| mgmt_broadcast_address | Set appropriately for the network used to assign Management IPs for Storage hosts. |
| mgmt_default_route | Set to the Management VIP of the TOR switch. |
| signal_vlan_id | Set to the VLAN ID of the Signalling network For Ex: 5 |
| signal_subnet_ipv4 | Set to the subnet of the Signalling network used to assign IPs for Storage hosts |
| signal_subnet_cidr | Set to the cidr notation for the Signalling subnet. For example 29 |
| signal_netmask | Set appropriately for the network used to assign Signalling IPs for Storage hosts and MySQL SQL Node VM's. |
| signal_broadcast_address | Set appropriately for the network used to assign Signalling IPs for Storage hosts and MySQL SQL Node VM's. |
| signal_default_route | Set to the Signalling VIP of the TOR switch. |
| occne_snmp_notifier_destination | Set to the address of SNMP trap receiver. For Ex: "127.0.0.1:162" |
