| 1.
- Configure SQL node
A
At Site 2, login to any management node. From the MySQL
Cluster Manager Client execute:
mcm> set server-id:mysqld:56=21 occnendbclustera;
mcm> set binlog-format:mysqld:56=row occnendbclustera;
mcm> set log_bin:mysqld:56=/var/occnedb/binlogs/mysql-bin.log occnendbclustera;
mcm> set relay_log:mysqld:56=/var/occnedb/mysql/mysql-relay-bin occnendbclustera;
mcm> set relay_log_index:mysqld:56=/var/occnedb/mysql/mysql-relay-bin.index occnendbclustera;
mcm> set expire_logs_days:mysqld:56=10 occnendbclustera;
mcm> set max_binlog_size:mysqld:56=1073741824 occnendbclustera;
mcm> set auto-increment-increment:mysqld:56=2 occnendbclustera;
mcm> set auto-increment-offset:mysqld:56=2 occnendbclustera;
mcm> set ndb-log-update-as-write:mysqld:56=0 occnendbclustera;
mcm> set slave-skip-errors:mysqld:56=1590 occnendbclustera;
mcm> set skip-slave-start:mysqld:56=TRUE occnendbclustera;
B
mcm> set server-id:mysqld:57=12 occnendbclustera;
| 2.
Restart all SQL nodes
- Restart SQL nodes
on Site 1
At Site 1, login to any management node. From the MySQL
Cluster Manager client execute:
mcm> stop process 56 occnendbclustera;
mcm> start process 56 occnendbclustera;
mcm> stop process 57 occnendbclustera;
mcm> start process 57 occnendbclustera;
- Restart SQL nodes
on Site 2
| 3.
Create replication users
- Create replication
user at Site 1
At Site 1, login to SQL node A. From the MySQL client
execute:
mysql> /usr/local/mysql/bin/mysql -h 127.0.0.1 -uroot -p<password>
mysql> GRANT REPLICATION SLAVE ON *.* TO 'myslave'@'<public IP of SQL node A at Site 2>' IDENTIFIED BY '<password>';
use at Site 2
At Site 2, login to SQL node A. From the MySQL client
execute:
mysql> GRANT REPLICATION SLAVE ON *.* TO 'myslave'@'<IP of SQL node A at Site 1>' IDENTIFIED BY '<password>';
| 4.
Initialize replication
- Get replication
information for Site 2
execute:
mysql> SHOW MASTER STATUS;
You will see output similar to the following:
| File | Position | Binlog_Do_DB | Binlog_Ignore_DB | Executed_Gtid_Set |
| mysql-bin.000003 | 154 | | | |
1 row in set (0.00 sec)
Note: This is just example
output; the values you see will be different.
- Initialize
replication at Site 1
execute:
mysql> STOP SLAVE;
Query OK, 0 rows affected, 1 warning (0.00 sec)
mysql> CHANGE MASTER TO master_host='<IP of SQL node A at Site 2>', master_port=3306, master_user='myslave', master_password='<password>', master_log_file='<binlog file>', master_log_pos=<binlog position>;
Query OK, 0 rows affected, 1 warning (0.05 sec)
mysql> START SLAVE;
Query OK, 0 rows affected (0.00 sec)
Where <binlog_file> is the value of the File
column in the output shown above, and <binlog_position> is the value of
the Position column in the output shown above.
- Get replication
information for Site 1
execute:
| mysql-bin.000001 | 580 | | | |
- Initialize
replication at Site 2
execute:
mysql> STOP SLAVE;
mysql> CHANGE MASTER TO master_host='<IP of SQL node A at Site 1>', master_port=3306, master_user='myslave', master_password='<password>', master_log_file='<binlog file>', master_log_pos=<binlog position>;
mysql> START SLAVE;
Where <binlog_file> is the value of the File column in the
output shown above, and <binlog_position> is the value of the Position
| 5.
Verify replication status
- Verify Site1
execute:
mysql> SHOW SLAVE STATUS \G;
*************************** 1. row ***************************
Slave_IO_State: Waiting for master to send event
Master_Host: 10.75.212.246
Master_User: myslave
Master_Port: 3306
Connect_Retry: 60
Master_Log_File: mysql-bin.000001
Read_Master_Log_Pos: 4175
Relay_Log_File: mysql-relay-bin.000002
Relay_Log_Pos: 3810
Relay_Master_Log_File: mysql-bin.000001
Slave_IO_Running: Yes
Slave_SQL_Running: Yes
Replicate_Do_DB:
Replicate_Ignore_DB:
Replicate_Do_Table:
Replicate_Ignore_Table:
Replicate_Wild_Do_Table:
Replicate_Wild_Ignore_Table:
Last_Errno: 0
Last_Error:
Skip_Counter: 0
Exec_Master_Log_Pos: 4175
Relay_Log_Space: 4017
Until_Condition: None
Until_Log_File:
Until_Log_Pos: 0
Master_SSL_Allowed: No
Master_SSL_CA_File:
Master_SSL_CA_Path:
Master_SSL_Cert:
Master_SSL_Cipher:
Master_SSL_Key:
Seconds_Behind_Master: 0
Master_SSL_Verify_Server_Cert: No
Last_IO_Errno: 0
Last_IO_Error:
Last_SQL_Errno: 0
Last_SQL_Error:
Replicate_Ignore_Server_Ids:
Master_Server_Id: 2155
Master_UUID: 41ea3e4f-0a6f-11e9-8d7a-fa163fe70331
Master_Info_File: /usr/local/mysql/data/master.info
SQL_Delay: 0
SQL_Remaining_Delay: NULL
Slave_SQL_Running_State: Slave has read all relay log; waiting for more updates
Master_Retry_Count: 86400
Master_Bind:
Last_IO_Error_Timestamp:
Last_SQL_Error_Timestamp:
Master_SSL_Crl:
Master_SSL_Crlpath:
Retrieved_Gtid_Set:
Executed_Gtid_Set:
Auto_Position: 0
Replicate_Rewrite_DB:
Channel_Name:
Master_TLS_Version:
Verify that the Slave_IO_Running and Slave_SQL_Running fields both
have the value "Yes".
Verify that the Last_IO_Errno and Last_SQL_Errno fields both have
the value "Yes". Verify that the Last_IO_Error and Last_SQL_Error field values
are both empty.
Last_IO_Errno: 0
Last_IO_Error:
Last_SQL_Errno: 0
Last_SQL_Error:
If the values of fields referenced above match the listed values,
then replication is working properly at this site.
- Verify Site 2
execute:
Master_Host: 10.75.213.245
Master_Port: 3306
Connect_Retry: 60
Master_Log_File: mysql-bin.000003
Read_Master_Log_Pos: 154
Relay_Log_Pos: 320
Relay_Master_Log_File: mysql-bin.000003
Replicate_Do_DB:
Replicate_Do_Table:
Last_Errno: 0
Last_Error:
Skip_Counter: 0
Exec_Master_Log_Pos: 154
Relay_Log_Space: 527
Until_Log_File:
Until_Log_Pos: 0
Master_SSL_CA_File:
Master_SSL_CA_Path:
Master_SSL_Cert:
Master_SSL_Cipher:
Master_SSL_Key:
Last_IO_Errno: 0
Last_IO_Error:
Last_SQL_Errno: 0
Last_SQL_Error:
Master_Server_Id: 1155
Master_UUID: a9a78193-0a6e-11e9-9dbe-fa163fab3df6
SQL_Delay: 0
Master_Bind:
Master_SSL_Crl:
Master_SSL_Crlpath:
Retrieved_Gtid_Set:
Executed_Gtid_Set:
Auto_Position: 0
Channel_Name:
Master_TLS_Version:
are both empty.
Last_IO_Errno: 0
Last_IO_Error:
Last_SQL_Errno: 0
Last_SQL_Error:
