Change MySQL root user password
Following is the procedure to change MySQL root user password.
As part of the installation of the MySQL Cluster, db_install container generates the random password and marked as expired in the MySQL SQL nodes. This password is stored in "/var/occnedb/mysqld_expired.log" file. so we need to login to the each of the MySQL SQL nodes and change the MySQL root user password.Table B-19 Change MySQL root user password
| Step No.# | Procedure | Description |
| 1. | Login to MySQL SQL Node VM. | |
| 2. | Login using mysql client | Login to mysql client as a root user
$ sudo su $ mysql -h 127.0.0.1 -uroot -p |
| 3. | Enter expired random password for mysql root user stored in the "/var/occnedb/mysqld_expired.log" file | Enter expired random password stored in
$ mysql -h 127.0.0.1 -uroot -p $ Enter password: |
| 4. | Change Root Password | Execute the following commands to change the
root password:
$ mysql> ALTER USER 'root'@'localhost' IDENTIFIED BY '<NEW_PASSWORD>'; $ mysql> FLUSH PRIVILEGES;Note: Here 'NEW_PASSWORD' is the password of the mysql root user. |
