YUM Repository Configuration
Introduction
To perform an installation without the system needing access to the internet, a local YUM mirror must be made of the OL7 latest, epel, and addons repository used by the OS installation.
A repository file will need to be created to reference this local YUM repository, and placed on the necessary machines (those which run the OCCNE installation Docker instances).
Prerequisites
Local YUM mirror repository for the OL7 'latest', 'epel', and 'addons' repositories. Directions here: HTTPS://WWW.ORACLE.COM/TECHNICAL-RESOURCES/ARTICLES/IT-INFRASTRUCTURE/UNBREAKABLE-LINUX-NETWORK.HTML
Subscribe to following channels while creating the yum mirror from uln:
[ol7_x86_64_UEKR5] [ol7_x86_64_ksplice] [ol7_x86_64_latest] [ol7_x86_64_addons] [ol7_x86_64_developer]
References
Oracle YUM mirroring directions:
https://www.oracle.com/technetwork/articles/servers-storage-admin/yum-repo-setup-1659167.html
Procedure Steps
Table A-1 Procedure to configure OCCNE YUM Repository
| Step # | Procedure | Description |
1.
Create OL7 repository mirror repo |
Below is an example of a repository file providing the details on a mirror with the necessary repositories. This repository file would be placed on the OCCNE Bootstrap machine that will setup the OCCNE Bastion Host. (directions on the locations in the installation procedure) [local_ol7_x86_64_UEKR5] name=Unbreakable Enterprise Kernel Release 5 for Oracle Linux 7 (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/UEKR5/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ [local_ol7_x86_64_latest] name=Oracle Linux 7 Latest (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/latest/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ [local_ol7_x86_64_addons] name=Oracle Linux 7 Addons (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/addons/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ [local_ol7_x86_64_ksplice] name=Ksplice for Oracle Linux 7 (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/ksplice/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ [local_ol7_x86_64_developer] name=Packages for creating test and development environments for Oracle Linux 7 (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/developer/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ [local_ol7_x86_64_developer_EPEL] name=EPEL Packages for creating test and development environments for Oracle Linux 7 (x86_64) baseurl=http://10.75.155.195/yum/OracleLinux/OL7/developer/EPEL/$basearch/ gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY enabled=1 proxy=_none_ |
