Artifact Acquisition and Hosting
Introduction
The OCCNE deployment containers require access to a number of resources that are usually downloaded from the internet. For cases where the target system is isolated from the internet, locally available repositories may be used. These repositories require provisioning with the proper files and versions, and some of the cluster configuration needs to be updated to allow the installation containers to locate these local repositories.
- YUM Repository Configuration is needed to hold a mirror of a number of OL7 repositories, as well as the version of docker-ce that is required by OCCNE's Kubernetes deployment
HTTP Repository Configuration is needed to hold Kubernetes binaries and Helm charts
- Docker Image Registry Configuration is needed to hold the proper Docker images to support the containers that run Kubernetes and the common services that Kubernetes will manage
- A copy of the Oracle Linux ISO. Download it from OSDC for OS installation. Contact MOS for more information.
- A copy of the MySQL NDB archive for database nodes. Download it from OSDC for OS installation. Contact MOS for more information.
